2019 C300 - Alignment, FrontEnd, Tire help
Old Jun 21, 2025 | 04:18 PM
Lukebmc's Avatar
c300 4matic 2019
hi,
I bought new c300 as certified preowned in 2021. Since than I replaced the tires twice. I keep having them align every 10000. Originally the dealership put on continental tires. ContiSport contact SSR>. $500 a piece. Run flats that are seasonal and can't run below 45. I store the car in the winter. I replaced the original set of tires once after 10,000 because of coupling. Dealership said it was cause of cold winter driving. I accepted that, and just bought a whole new set of continental contisports ssr.
Since I only got about 15000 miles with being stored in the winter on this new set and the coupling is happening again. I am assuming these tires are not meant for this vehicle. Can anyone recommend a set of tires that can get 40000k, or are a good tire for the C-300? Could it be something beyond the tires, such as alignment, front end complications. I had them run diagnostics on that twice as well. everything checked out.
any help would be great!
thanks MBworld
Old Jun 22, 2025 | 02:47 AM
ygmn's Avatar
2015 E400 Sedan
are they wearing evenly across tread width?
Not much they can do on alignment to STOCK MB except for toe.
Old Jun 24, 2025 | 03:03 PM
Lukebmc's Avatar
c300 4matic 2019
they are coupling. Wearing in the middle of the tire. 2 time this is happening.
Old Jun 25, 2025 | 02:33 AM
ygmn's Avatar
2015 E400 Sedan
wear in middle but not edges means too much air pressure.
Try lowering the front pressure
