W205 Overheating Gauge Problem – White Goo in Radiator?
Old Sep 27, 2025 | 05:43 PM
Hello32's Avatar
C300
I recently picked up a 2016 Mercedes C300 (W205) from auction with about 85k miles. The car drives like new. I drove it about 50 miles home from the auction with no overheating issues at all.
The next morning, as soon as I started it, the temperature gauge jumped all the way to hot. I opened the hood and didn’t see any boiling coolant, so I figured maybe the thermostat was the problem. I replaced the thermostat and flushed the system. While doing that I noticed some kind of white goo/sludge in the radiator — there was quite a bit of it, with chunks, but I did my best to flush it out.
Unfortunately, the issue is still happening. The gauge immediately shows overheating, but the engine doesn’t seem like it’s actually running that hot.
So far I’m thinking it could be:
  • Bad coolant temp sensor or cluster issue
  • Water pump not circulating properly
  • Cooling fan problem
  • Air still trapped in the system
  • Or worst case, head gasket/coolant contamination from previous owner
Has anyone run into this before on a W205 with the M274 engine? Any advice on what to check next would be a huge help.
Old Sep 28, 2025 | 01:56 AM
gadnyara's Avatar
C220d 2019
Originally Posted by Hello32
The next morning, as soon as I started it, the temperature gauge jumped all the way to hot...
The gauge immediately shows overheating...
Sensor(s), wires, CPU, connectors...
Short circuit.
Old Sep 28, 2025 | 05:44 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
First thing you might wanna do is check for exhaust gases in your coolant. Make sure this thing wasn’t sent to auction due to a bad coolant and oil mixing issue. If you find that that is not the case, and you just need to flush everything, it’s time to get out the garden hose and flush out your entire cooling system of that goo. You will want to run the water in the reverse direction of the normal water flow.
Old Sep 28, 2025 | 08:29 AM
streborx's Avatar
Top Answer: 1
G550
Sounds like someone decided to fix a coolant leak with an overdose of a leak fix additive, and now the system is clogged.
Old Oct 19, 2025 | 05:58 PM
Andy74's Avatar
W205 2015
Sensor issue. Why is it showing immediately that the car is hot.
