Does using lowering springs on a c400 wear out tires faster?
Old Apr 26, 2026 | 03:59 PM
Dns230's Avatar
2015 c400 1998 c230
I lowered my w202 with eibach springs and I feel like it eats tires like crazy now in the rear because I don’t have the camber adjustment.
would this also be an issue if I use h&r springs on my w205 c400 awd?
Old Apr 26, 2026 | 05:57 PM
superswiss's Avatar
2019 C63CS
Yes, absolutely. Without correcting the alignment, for which you'll need adjustable control arms to do, lowering increases the negative camber, so the tires are riding on the inner edge which consequently leads to camber wear and less optimal contact patch. Lowering changes your suspension geometry. While it may improve the looks, it doesn't really improve the suspension and everything related to it, unless you take a more comprehensive approach. Lowering springs also compromises the dampers, because you force them to be always overcompressed, so they no longer work in their ideal range, which can further make itself known via undesired tire wear.
