Changing Main Battery
but what do I need to do to keep the car's electronics happy? (reset Battery counter?, reset / restore other settings ?)
... and how would I do these things? Do I need a compatible OBDII-scanner?
Thanks so much for any advice and help.
Trombone77
Trombone77
I read somewhere, that the C300 adjusts the charging voltage depending on the age (internal resistance)
of the battery. More voltage and more charging current when the battery is older. Thus, unless a new
battery is registered with the board computer, the charging current might be larger than necessary and
wear out the battery faster. Is this just nit-picky or a real concern?
Also, can somebody suggest a suitable OBDII scanner for these cars? I only have a basic device that
doesn't seem to be able to do the trick.
Thanks again,
trombone 77
Thanks again,
trombone 77
I want to add Launch CReader Elite Benz V2.0 has something called a BBA version which apparently stands for Benz BMW Audi, it is around the same cost or just a few dollars more, it also has physical navigation buttons. So that is a good option as well for those who have other models or just want to have physical buttons.
Furthermore, you can still purchase (subscription) the 3 German brands from the app store on the regular Launch CReader Elite Benz V2.0 but it will always be more expensive than all 3 brands built-in purchased once.
Discussion on this scanner linked:
https://mbworld.org/forums/coupe-roa...tc-2018-a.html
https://mbworld.org/forums/glc-class-x254/926639-75-scan-tool-choice-glc300.htm
I am not sure if you really should buy this scanner just for one time use like registering the battery unless you find use for it somehow.
Some data points that might be useful to people who read this thread: If you disconnect the state of charge system (at the negative battery plug) two things happen. It goes to a straight 14.1 charge always (like many other cars do), and it disables the Eco Start/Stop feature. I often leave the state of charge plug disconnected in order to not be bothered by the Eco Start/Stop nonsense. In 10 years of ownership, I have not seen an effective difference in having the charging be a constant 14.1, rather than going between 13.4 and 14.8. I've gotten ~5 years out of each battery and do a crazy amount of in-town driving. The car is now approaching 140,000 miles.
