2016 C300 Transmission lurch when attempting to downshift
Old Today | 04:36 PM
Bmarcinczyk14's Avatar
2016 C300 w/ sport package
I've been noticing the last 5,000 miles or so sometimes when I give more throttle while moving when the transmission should downshift to a lower gear it will give this unsettling lurch almost like a harsh bang as it attempts to downshift and it doesn't even end up shifting into the lower gear like it should. I have about 62,000 miles and recently had the transmission fluid flushed at the dealer hoping that issue would be fixed but unfortunately it's still there. Its hard to re-create the perfect conditions to replicate the issue but it's very unsettling and has more worried my transmission is on its way out. Otherwise the normal shifting seems a bit smoother since the fluid change. Any ideas or recommendations on what to do?
Old Today | 05:17 PM
W205C43PFL's Avatar
Might want to try transmission learning reset.
Old Today | 06:24 PM
Do you know if that's something thats done during a transmission fluid flush?
Old Today | 07:35 PM
W205C43PFL's Avatar
After, you could do it now as long as you have XENTRY or get your dealership to reset it for you.
Old Today | 07:37 PM
If it's something the dealership does after the fluid flush then that means it was recently done and didn't fix this problem.
Old Today | 07:38 PM
W205C43PFL's Avatar
No they don't reset it as part of the procedure at least not what I remembered from WIS.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
