C-Class (W206) 2021 to
W206 - Two minor annoyances with front seats for service.
Old May 25, 2022 | 03:28 PM
GSOTXL's Avatar
2019 MB C300 4Matic (me); 2021 BMW 530i xDrive (husband)
Base of driver’s seat where seatbelt is housed is a bit off and I can’t appear to just snap it properly into place. The passenger side, however, is perfectly aligned. I just noticed it the other day when adjusting my seatbelt and refining my seat settings.
Passenger front seat headrest squeaks when driving, unless I hold it or rest my hand against it like this. Started the week after delivery,
Old May 26, 2022 | 01:04 PM
MRC250's Avatar
Mercedes Benz C250 Sport Sedan
Does the squeak happen when going over bumps or is it just constantly squeaking? I've noticed some plastic sounds creaking randomly sometimes as well.
Old May 26, 2022 | 03:03 PM
scriptx's Avatar
F150 Lariat
My passenger headrest does the same. I found lowering it all the way gets / reduces it.
Old May 26, 2022 | 04:12 PM
GSOTXL's Avatar
It’s basically all the time.
Old May 26, 2022 | 04:13 PM
GSOTXL's Avatar
Thanks!
I tried that already and didn’t notice any improvement yesterday, but magically today it stopped. Hmmmmm.
Old Jan 17, 2023 | 10:54 PM
camarc68's Avatar
2022 C300 Sedan
Just curious if the seat noise ended up stopping for you? If not, was the dealership able to fix it? My driver's seat creaks/ pops regularly - notice it particularly during turns and over speed bumps. I've taken it to the dealership twice - they made some type of minor modification to the seat back cover but this wasn't successful. No reduction in the seat noise at all. I'm scheduled to take the car back in a couple weeks - just curious if there was a fix. Thanks!
Old Jan 18, 2023 | 03:17 AM
GSOTXL's Avatar
Hi,
it did stop and hasn’t come back. The dealer service dept just made minor adjustments. I was skeptical but thankful that whatever they did worked.
Old Jan 18, 2023 | 11:11 AM
camarc68's Avatar
2022 C300 Sedan
That's great news. I'll be taking my car in to dealership in a couple of weeks. Hopefully third time will be a charm and they'll be able to fix it.
Old Jan 19, 2023 | 07:56 AM
Glamisfan's Avatar
C300
I saw a post on Facebook that said an independent mechanic sprayed some WD-40 on the passenger headrest and that made the squeak go away. I was thinking a little shot of silicone spray in there would be helpful?
Old Jan 24, 2023 | 09:47 PM
Benea's Avatar
C300
@camarc68 The source of the noise you are hearing might be different from the one mentioned in this thread.
I had a similar noise like you described (popping and clicking noise coming from behind the seat on bumpy roads and corners, it sounds like a noise coming from a plastic). I took it to the dealer, and they fixed it by replacing the backrest cover of the driver's seat. The following paragraph is from the service invoice:
"Performed test drive, confirmed creaking from driver's seat behind the backrest. Removed seat backrest cover and performed second test drive, confirmed noise no longer present. Ordered a new backrest cover and installed it. Along with lubricating all contact points with A0009893660 oil from NVH Kit. Confirmed noise no longer present."
Now, I hear the same noise coming from the passenger's side as well, so I will take the car back to the dealer again.
Old Jan 25, 2023 | 01:07 AM
camarc68's Avatar
2022 C300 Sedan
Thanks for the information! I'll share the info with he service advisor during my next visit. During the two prior attempts for them to address this, I believe the added teflon tape to the inside edge of the plastic backrest, but that didn't work. In fact, there was no in the noise at all.
Old Mar 2, 2023 | 03:27 PM
camarc68's Avatar
2022 C300 Sedan
Just thought I'd provide a quick update. I took my car to the dealer a few weeks ago for the driver's seat noise issue I mentioned earlier. This was the third visit for this issue- the first two they were focused on the plastic backrest panel as there was a service bulletin regarding but that didn't resolve the problem with my car at all. This time, I'm happy to say, they were able track down the problem and address it. I believe what they found was a bit strange (copied some text from the service invoice below), so thought I would share. Hopefully this is the last of the little issues I've had since I bought the vehicle in August.
"...Inspected the underside of the seat frame and could not find any broken or worn out components. All seat components worked properly when commanded. Removed the seat back trim panel and inspected the inside of the seat frame and hinge points. Noted corrosion on the seat back motor, hinge spring bar and several other internal components. Rusty components inhibit smooth flexing motion of spring mat and other motion-activated components causing audible noises.
"Removed drivers seat, disassembled seat bottom frame. Removed seat back cover, removed. and disassembled seat back frame. Replaced seat bottom frame with rusted components. Replaced seat back frame with corroded elevation motor and oxidized components....."
Old May 10, 2023 | 07:10 PM
W205C43PFL's Avatar
Thanks! Glad they figured it out, hopefully your post will help those who come across this post with clueless dealership personnel.
Old May 10, 2023 | 11:09 PM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Ditto on my brand new EQE 500 SUV. Compared to driver seat headrest that plastic piece you're holding is visibly looser. I only hear it when driving over rough pavement or the train tracks near my house but it's right in my fookin' ear and really grates on my nerves. Becomes worse in hot weather and less so when cool outside like today. Car is going in for service this Friday after just two weeks of ownership.
Old May 11, 2023 | 03:22 PM
W205C43PFL's Avatar
Sorry to hear that, hopefully they address it quickly.
Old May 12, 2023 | 02:51 PM
They fixed it in three hours by partial disassembly and applying felt tape to the surfaces that were loose and coming into contact with each other. That appears to have resolved the issue for me.
Old May 13, 2023 | 08:25 AM
W205C43PFL's Avatar
Very nice thanks for letting us know and glad it solved it for you
Old Jul 24, 2025 | 04:48 PM
captain power's Avatar
Mercedes C200 (W206)
I am having same issue, the dealer replaces the headrest plastics but still the rattle noise coming. I went to dealer 3-4 times for this reason and I am really getting tired about this problem. Any help will be much appreciated. Thanks.
https://drive.google.com/file/d/1NEH...ew?usp=sharing
Old Jul 24, 2025 | 11:14 PM
W205C43PFL's Avatar
I am not sure if it is the same issue as the W205 since they different part numbers and different designs, but worth looking into: https://forums.mbclub.co.uk/threads/...adrest.253513/
https://mbworld.org/forums/c-class-w...headrests.html
Old Aug 1, 2025 | 01:04 AM
I have seen this post and the problem is exactly the same. https://mbworld.org/forums/c-class-w...-interior.html
Also I am sharing my problem here: https://drive.google.com/drive/u/0/f...sCe7lIeuv_ilXT
I will go the dealer again probably on 11th August and leave the car for further inspections. If anyone has an idea about the resolution, I will be very much appreciated.
Old Aug 1, 2025 | 01:36 AM
W205C43PFL's Avatar
I see, sorry that I wasn't able to help.
Old Aug 18, 2025 | 07:13 AM
Hi,
Could you please let us know what the dealer service has done? I brought my car maybe more than 5 times and more than 15-20 days they spent but still they could not solve the problem.
Old Aug 22, 2025 | 01:07 AM
Finally, it has been fixed by greasing the two springs at the each bottom corner of the seat according to the service supervisor. For your information.
Old Oct 2, 2025 | 08:57 AM
unfortunately again that noise came back. Anyone has an idea how to fix it?
