C-Class (W206) 2021 to
Deactivating keyless entry
Old Mar 13, 2023 | 01:18 PM
Chuci_24's Avatar
Glc x254
Anyone know how this is done with the new Mercedes keys like below.
On my old a class (w177), if you double pressed the lock button it would deactivate the keyless entry. This doesn't work anymore so wondering if it's a different combo now
Old Mar 13, 2023 | 01:46 PM
W205C43PFL's Avatar
Hmmm I don't think they changed it I still see people doing so and it still works, did you happen to check the user manual if it tells you anything, alternatively you could also use a faraday pouch. Sorry if my reply wasn't as helpful as you hoped.
Old Mar 13, 2023 | 01:48 PM
superswiss's Avatar
2019 C63CS
Did you misplace your owner's manual?
Old Mar 13, 2023 | 06:07 PM
W205C43PFL's Avatar
Thanks as always forum member superswiss, so I stand corrected and that there were changes, I could had sworn that some W206 people got it to work by double pressing the lock button but as you confirmed for us that I remembered it incorrectly. Interesting how MB changed it to this, maybe people were complaining that keyless go was not working not knowing they press the lock button twice in quick succession in previous models? I learned something today.
Old Mar 13, 2023 | 06:24 PM
superswiss's Avatar
2019 C63CS
Yeah, it's possible that the double-click was too easy to trigger accidently and perhaps could even happen with the key in your pocket and doing a "butt-lock" so to speak. Also since the last generation of key fobs were introduced with the W213 and then added to other models such as the FL W205, the fobs now also have a motion sensor in them and deactivate automatically after 2 minutes of not sensing any motion, so the manual deactivation has become less important. This change was done in response to the relay attacks that have become popular in recent years, so now if you leave the fob sitting around in the house, you no longer have to worry about thieves stealing the car from your driveway by relaying the key fob signal, and at the same time it preserves the battery.
Old Mar 13, 2023 | 06:29 PM
Chuci_24's Avatar
Glc x254
I didn't no, and I've seen this... Its the "keyless go" part which threw me. I was more interested in just keyless entry which previously was different to disabling keyless go. It seems a tad overcomplicated getting out the car and doing the above rather than the previous double lock press.
​​​​​​Edit to say - even previous keys had the built in motion sensor which disabled the key after a period of no motion.
Old Mar 13, 2023 | 06:34 PM
superswiss's Avatar
2019 C63CS
How was deactivating keyless go and entry different before? In my FL C205 C63 they are both disabled with the double-click and there's the motion sensor as mentioned. The PFL W205 had the removable button to disabled keyless go and no motion sensor. Agreed, it's a tad complicated now, but as I said, there's less of a need, IMO. I pretty much never need to manually deactivate it.
Old Mar 13, 2023 | 06:36 PM
Chuci_24's Avatar
Glc x254
I should probably add that I'm London based sometimes they clone when you click the lock button from nearby or after you're walking from the car. The double lock was just a nice and easy safety addition
Old Mar 13, 2023 | 06:42 PM
superswiss's Avatar
2019 C63CS
Well, if they clone the key then deactivating it doesn't help. It only deactivates the fob. If they managed to clone it while you are deactivating it, they'll get into your car. Doesn't seem cloning is really still a thing as the fobs these days use changing codes. Each time the car is locked/unlocked the code changes. That's why the relay attacks are much more popular. Somebody actually has to follow you while the second person stands near your car. In that case deactivating your fob is a nice safety addition as the fob will sense motion while you are walking and not deactivate itself.
Old Mar 13, 2023 | 07:15 PM
W205C43PFL's Avatar
Not sure in that case a faraday pouch will help but probably not depending on how they clone it.
Old Mar 14, 2023 | 04:59 PM
Serg675's Avatar
Mercedes-Benz C 300 2022 4MATIC
Actually for 2022 C300 it's still doble click on the lock button. Don't know from what manual screenshot was taken in the post below. At least it works this way for my 2022 C300. May be 2023 is different.
Old Mar 14, 2023 | 05:04 PM
superswiss's Avatar
2019 C63CS
Originally Posted by Serg675
Actually for 2022 C300 it's still doble click on the lock button. Don't know from what manual screenshot was taken below. At least it how it works for my 2022 C300.
That was taken from the 2023 owner's manual.
Old Mar 14, 2023 | 05:11 PM
Serg675's Avatar
This means that 2022 and 2023 are differet in this regard.
Old Mar 14, 2023 | 05:24 PM
superswiss's Avatar
2019 C63CS
It appears that way. Maybe the new bulkier key fob design proved to be more prone to accidentally double clicking the lock button with the fob in one's pocket. The previous key fob design was slimmer and less bulky. The new fobs are kind of a step backwards, IMO.
Old Mar 14, 2023 | 05:56 PM
Serg675's Avatar
Yes, I experience this myself time to time. Touching the door handle and nothing happens.
Old Mar 14, 2023 | 09:47 PM
W205C43PFL's Avatar
Interesting, so that means I was right yet wrong...
