C-Class (W206) 2021 to
Dashcam "Device is too slow"
Old Jun 22, 2023 | 10:56 AM
23C300W4's Avatar
Veteran: Air Force
2023 C300 4MATIC AMG Line
My factory dashcam function is set to Loop Recording, which automatically starts every drive of the car, and will overwrite the oldest recording when the flash drive gets full. I have an inexpensive (~$10) 128GB USB-C drive for this purpose.
I get the titled error sometimes, and have determined that it happens when the flash drive gets full. I find myself wondering if it's the cheapo drive itself or some issue with MBUX. This only happens every few weeks, so it's not a huge issue, but it is annoying when you're driving down the road and get the error.
Anyone have any thoughts?
Old Jun 22, 2023 | 12:58 PM
giovane's Avatar
2023 C Class
Never happened to me.
I bought this usb A flash drive and a usb C to usb A cable
https://www.amazon.com/dp/B07857Y17V?ref=ppx_yo2ov_dt_b_product_details&th=1 https://www.amazon.com/dp/B07857Y17V?ref=ppx_yo2ov_dt_b_product_details&th=1
Old Jun 22, 2023 | 01:10 PM
23C300W4's Avatar
Veteran: Air Force
My dealer gave me that adapter cable at delivery. I didn't want that flopping around in the well so I bought a USB-C flash drive. I did buy USB-C to lightning cables for our phones and two for back seat passengers (which will be pretty rare, but I'm a nice guy ). Looks like future iPhones will be USB-C, though (thanks Europe!), so I'll have to buy new cables when we replace ours, whenever that is.
Old Jun 22, 2023 | 01:14 PM
giovane's Avatar
2023 C Class
You are right, the usbC to usbA cable came with the car. That's why I couldn't find it among my early C Class purchases on Amazon.
Old Jun 22, 2023 | 01:49 PM
superswiss's Avatar
2019 C63CS
It's very likely your cheapo flash drive. The write speed is probably too low. Also just because it's USB-C doesn't mean it supports a fast USB 3 connection. It may only be USB 2. You have to look at the specs. I haven't looked, but the owner's manual may specify the required specs for the flash drive to use. Often devices have specific minimum requirements for write speed. An HD video feed requires a certain bandwidth.
Old Mar 18, 2024 | 04:41 PM
S.W's Avatar
S.W
2018 GLC300, 2025 GLE 450e
Great info on this thread!
One concern I had was leaving a thumb drive plugged in and getting in the way when accessing the center console. The Samsung drive looks like the smallest physical size but doesn't it still get in the way? Would be nice if fast compact sized drives that use a cable could rest in the small cubby in the console but typically those cables are too short.
​​ Also, approximately how quickly does a 128GB drive get filled up?
Old Mar 18, 2024 | 05:50 PM
RoyalCanuck's Avatar
C300
128gb can only hold up to 1 hour of footage.
I'm encountering the same issue and I'm using the USB A to USB C adapter provided by Mercedes. My guess is that the adapter is only 3.0 compatible although my USB is 3.1, which is lowering the speed of the drive. I'm going to change the cable to see if it resolves it.
Old Mar 18, 2024 | 05:55 PM
W205C43PFL's Avatar
MB is pretty particular with the size of the drive and the file format.
Old Mar 18, 2024 | 06:40 PM
C300
It was working perfectly fine before the latest MBUX 2.4 update that I received today (in Canada).
Old Mar 18, 2024 | 06:57 PM
W205C43PFL's Avatar
Hmmm. I wondered if they introduced some additional hardware requirements, if so why? Something like ensure stability of the system or something?
Or maybe I am just thinking too much and it was actually because of bugs/glitches introduced in the update?
Old Mar 18, 2024 | 07:28 PM
Murton's Avatar
W206 C300e AMG Line Premium Plus with driver assistance package
I have this memory stick Kingston DataTraveler microDuo 3C USB Flash Drive 64GB USB Gen 3 Type-C and Type-A - DTDUO3CG3/64GB https://amzn.eu/d/bKRbxIV
I was getting the same error on average every couple of hours or so. Looking at the reviews the write speed isn’t the best so that might be the cause.
However here in the uk it doesn’t start automatically and with the poor quality I fitted a fitcamx dashcam instead.
Old Mar 20, 2024 | 09:07 AM
23C300W4's Avatar
Veteran: Air Force
I use the below-linked 256GB Samsung device. It's quite small and fits in the armrest storage console USB port quite nicely. It's also screaming fast, so we stopped getting the "too slow" errors we got with other drives.
Amazon Amazon
Old Apr 25, 2024 | 02:08 PM
Arinum's Avatar
2023 C300
Fine until update
I too was having zero issues until the update. Now it seems no matter what I use I get the “device to slow” message. Anyone else having this issue and possible fix?
Old Apr 25, 2024 | 02:10 PM
23C300W4's Avatar
Veteran: Air Force
Read the post before yours - this drive, though not cheap, was my solution.
Old Apr 25, 2024 | 02:14 PM
Arinum's Avatar
2023 C300
I did try the one you linked. I’m still getting the message. As I stated in my post. No matter what I use I’m getting the message. It started after the update.
Old Apr 25, 2024 | 03:27 PM
C300
I was only able to get it to work using the USB linked above.
Old Dec 22, 2025 | 12:42 PM
charles.soori's Avatar
2014 ml63 and 2014 ml350 bluetec
For me I tried this device and it use work fine till a software update. I bought two of these same issue. Not sure what else to try.
QUOTE=23C300W4;8942892]I use the below-linked 256GB Samsung device. It's quite small and fits in the armrest storage console USB port quite nicely. It's also screaming fast, so we stopped getting the "too slow" errors we got with other drives.
Amazon Amazon
[/QUOTE]
Old Apr 1, 2026 | 03:43 AM
crm75's Avatar
Is it possible to save videos on phone or take out the card/stick and play the videos on computer?
Thanks!
Old Apr 24, 2026 | 07:38 AM
jime's Avatar
Veteran: Navy
From: Fremont California in the San Francisco Bay area
2024 Mercedes E450
I used the Samsung 256GB USB-C version 3.2 stick listed by giovane as the solution for almost 2 years with no issues. Now "media too slow" for even new 3.2 sticks. Anyone have a different solution?
