C-Class (W206) 2021 to
The Rear Cup Holder in W206 fails to open.
Old Jun 30, 2023 | 02:44 AM
Sam.Reda's Avatar
C200 2022
Has anyone else encountered a problem with the Rear Cup Holder being stuck and not opening, even after trying to click it multiple times? If so, is there a solution or workaround for this issue?
Old Jun 30, 2023 | 03:20 AM
schizophonic's Avatar
C300e
It took a bit of getting use to, but you push it in to open and then push gently for again for the cup holder part.
How are you doing it?
Old Jun 30, 2023 | 08:18 AM
W205C43PFL's Avatar
To add to that, OP, make sure not to push it back all the way to the end or that will just close it, as mentioned, push gently and release then the second stage will pop up revealing the cup holders.
Old Jul 12, 2023 | 08:21 AM
Sam.Reda's Avatar
C200 2022
same as what you explained, i will take it to the dealer to check it, i believe it is factory issue as i never opened it
Old Jun 16, 2024 | 03:24 PM
Veysel's Avatar
C class W206
Mine too isn't even opening
Hey, did u solve the problem, and if you did how?
mine is stuck and won't open at all.
Old Apr 28, 2025 | 05:35 AM
Sam.Reda's Avatar
C200 2022
still i`m not able to open it , it is really annoying me .
