C-Class (W206) 2021 to
View Poll Results: Do Charging Iterruptions work for you?
Yes - Car remembers any settings I make
0
0%
No - I have to reset the interruption period
5
100.00%
Voters: 5. You may not vote on this poll
C300E Charging Interruptions
Old Jan 21, 2024 | 10:25 AM
mikejluk's Avatar
C300e
I use the charging Interruptions feature to take advantage of overnight off-peak electricity rates. It works as expected, but after a journey or two the interruption period sets itself to 12:00 am to 12:00am, meaning I have to constantly reset it. My dealer has been upable to resolve this.
Interested to know if anyone else has this problem, if if your cars remember the charging interruptions when set.
Old Jan 21, 2024 | 11:02 AM
Murton's Avatar
W206 C300e AMG Line Premium Plus with driver assistance package
Is that a setting something only available in the car as I haven’t seen it in the app?
I use the scheduled charging feature on my podpoint charger as it’s easy to set a schedule in the app. If I want to override it then I just hit the ‘charge now’ button and select the number of hours.
Old Jan 21, 2024 | 11:32 AM
mikejluk's Avatar
C300e
the setting is available in the car & Mercedes Me app. I often charge with a granny cable as our other car is fully electric & we only have one charger.
Old Jan 21, 2024 | 11:45 AM
Murton's Avatar
Ah ok. It is there but I hadn’t noticed it before.
I know if I use the standard profile and set a different charge level to charge up to then it seems to reset itself. So I have a home program set and just switch to that when I don’t need to charge to 100%
However charge interruptions cannot be set per charging profile so that isn’t a workaround you can do. That’s why I don’t use it. Most of the time I want to charge overnight but sometimes I need to topup in the evening which is much more awkward to do via the Mercedes app.
In general the way the car handles charging schedules is very poor. I wish they wouldn’t link the preheat time into the charging schedule. If I want to charge by 5:30 because that’s when the cheap electricity rate ends then i cannot set the car to warm up by 7:45 because the two features are linked. So I have a timer set on the podpoint charger to start at 0:30 and finish at 8:00. It charges the car and then sits at end of charge and I can manually turn on the preheat if I wish and then unplug the charger when I leave.
Old Jan 22, 2024 | 02:34 AM
schizophonic's Avatar
C300e
I dont personally use the charge interruptions as the software is not fully there yet with its bugs and quirks. I remember i tried the pre-heat schedule plan and the next time I tried to charge, nothing happened. In the end I ended up tampering with the quick charge setting on my app and charging then suddenly worked. So the scheduled planning on the car isn't something i would trust. Setting the charging timer on the power wall might be the best option if you have an electric charger at home. I'm only using the 3 pin power plug wall charging at the moment.
Old Apr 23, 2024 | 08:44 AM
craig085's Avatar
e300de
Same issue on e300de
charge interruption sets it’s self to 12:00-12:00 meaning the car will refuse to charge after a trip or two, very annoying and basically crippling the functionality completely. No way to take advantage of off peak rates without using a Zappi or similar dedicated car charger with on board charge settings.
this is going on 3 months now without a fix.
Image of setting screen. As you can see, set from 7am -2am. After one successful evening it will revert to 12:00-12:00 meaning no charging will take place full stop.
Old Apr 23, 2024 | 09:11 AM
mikejluk's Avatar
C300e
My local dealer had my car for best part of 4 weeks trying to resolve this. Most of that time was spent waiting for MB UK to respond. They did something unrelated to the charging schedules (sorry, can't remember what), and now the interruptions will stay for 4 or 5 charging cycles before resetting. Progress of sorts.
The car is with them again now, due to it dying last week. They've done some software updates & replaced a pre-fuse box, so waiting to see if any of that fixes the issue.
Old May 29, 2025 | 01:12 AM
stuartf9's Avatar
Exact same
mine is doing exactly the same meaning endless mornings with no charge. I would be interested to see if they sort yours.
Old May 29, 2025 | 08:25 AM
Murton's Avatar
Have you received the recent ota update to the charging system. It says it improves functionality during ota updates.
Its not installing on my car so I can’t test it.
Old May 29, 2025 | 10:31 AM
mikejluk's Avatar
C300e
the dealer had several more attempts to resolve the issue, without success and so I rejected the car last November. They said that they would inform me if they ever did solve it, but passed the car on soon after.
Old Jun 14, 2025 | 07:55 AM
C300eOwner's Avatar
C300e
I have a 2024 C300E, exactly with the same problem. It went back to the dealership more than 5 times already. It improved after some interventions, but still happens from time to time (more than once a month). Also, when this happens the gearbox seams to be reset also because it gets jerky for some kms.
Old Sep 23, 2025 | 03:43 PM
dnldaniel's Avatar
W214 400e
Same thing happens in my Mercedes E W214 400e. Continuously reseting to 00:00 (both interruptions as I've got two).
