C-Class (W206) 2021 to
Stuck Electronic Parking Brake
Old Jul 14, 2025 | 05:09 PM
Kristopher49's Avatar
2024 C300
I tried to take my 2024 C300 for a drive today after having it parked up for a month. After releasing the electronic parking brake the car still won’t go forwards or backwards. Has anyone else had this issue? If so how did you resolve it?
Old Jul 14, 2025 | 07:10 PM
AMPERAGE's Avatar
W206 C43
The rear pads can stick to the rotors, especially if the car has been outisde and there's a bit of surface rust. Assuming that you can hear the parking break release, you should be fine to give the the car a little throttle and they'll break free.
Old Jul 15, 2025 | 12:27 AM
camarc68's Avatar
2022 C300 Sedan
I had something similar happen to me once. In my case it seemed to the problem occurred after washing the car and then immediately parking it in the garage for several days before driving it. So, to avoid this problem from happening again I now drive my car a short distance after washing it to get some of the water off of the brake pads. That seems to be working for me.
Old Jul 15, 2025 | 12:59 AM
Alexie's Avatar
It sounds like moisture was causing the issue. Driving it briefly after washing is a smart fix. For your original question, just double-press the ignition button to shut it down without locking.
Old Jul 15, 2025 | 03:42 PM
2024 C300
Thanks everyone. After rocking it a bit and applying some more gas in reverse, it got unstuck. Drove around a bit and applied to brakes to clear up some rust from the rotors.
Old Jul 16, 2025 | 12:53 AM
W205C43PFL's Avatar
As mentioned, it is stuck due to the rust.
