C-Class (W206) 2021 to
PTC Heater
Old Sep 12, 2025 | 11:30 AM
robster52's Avatar
PTC Heater
My new to me 2023 C300e has been with the dealer with a HV battery charging fault (charges, throws an error and restarts every 15mins or so). After advice from Germany they changed the AC/DC controller (they could have meant the inverter) but that didn't solve the problem. Now they plan to change the PTC heater. Isn't this for cabin heating? could it be linked to a charging fault
Old Sep 15, 2025 | 08:57 AM
nearwater4me's Avatar
'25 S580
So for comparison on another brand's EV system - which is the field I work in,
The High Voltage system consists of HV battery, battery charging system, inverter-motor, and junction boxes linked to other accessories like PTC heater, battery heater, etc.
This HV system is separate from the regular 12V accessories system, with the HV battery and DC-DC charger converting the HV DC to 12V DC for charging the 12V battery - like the alternator on ICE cars.
When there's an issue within the HV system, such as isolation fault, it could cause all sorts of issues with charging and drivability.
Depending on what DTC/fault code or the electrical characteristics the technicians found, they might've been able to pinpoint it to the PTC heater, which is very possible.
I'd trust their diagnostics and give them the chance to fix the issue.
If the PTC is not the culprit, the issue will persist.
Hope this helps!
Old Sep 15, 2025 | 04:05 PM
robster52's Avatar
It does, thanks for the reply.
Old Sep 17, 2025 | 08:34 AM
Murton's Avatar
W206 C300e AMG Line Premium Plus with driver assistance package
The heater may also heat the battery or it might have a separate battery heater. If that fails it could well trigger a charging fault.
Old Sep 17, 2025 | 10:29 AM
'25 S580
Curious if the PTC heater replacement fixed the issue
Old Sep 17, 2025 | 02:12 PM
robster52's Avatar
Got the car back today and it's fixed (touch wood) so looks like PTC heater was the issue. Tech said without using the word "common" he's done a few and merc are aware of the problem....
Thanks for the help guys
