hybride dynamic select options..
I've had two questions since I bought my C300E (W206).
1. When I start the car in hybrid mode in the morning, the gasoline engine stays off. But if I press the accelerator too hard while driving, the gasoline engine kicks in and revs immediately, up to 3,000 rpm or more. Isn't this harmful to the engine or its longevity?
2. Is there an option to drive with the gasoline engine and electric motor (i.e., full power mode) without using sport mode? I find myself putting it in sport mode because I want to drive with all the power the car has. However, I find it annoying that you can't adjust the transmission in sport mode. It shifts too late and is very jerky. I know this often happens in sport mode, but it's the only mode where the engine doesn't shut off every time.
I hope someone knows a solution.
Sincerely,
Sport mode is the only way to keep the engine always on. Unfortunately you can't control the transmission separate from the engine mapping, so with engine in Sport, the transmission is in Sport as well. You can use the Individual mode to keep other things in comfort such as the suspension if you have adaptive suspension, but the engine and transmission mapping are one setting.
