Will adding OEM Charger Pad- unlock digital key as well
Subscribe
Nov 15, 2025 | 04:51 AM
Hi All,
My 2023 W206 C300 does not have the oem charger pad which apparently has something to do with usage or at least programming of the digital key option. If I buy and install the OEM charger pad in the center console will that also make a digital key possible? I've attached a list of all of my car's options.
Thanks!!Standard Accessories
12B Owners Manual
14U Smartphone Integration
16U Apple CarPlay™
17U Android Auto
232 Garage Door Opener
234 Blind Spot Assist
241 Power front left seat with memory function
242 Passenger Seat Memory w/ adj. Thigh Support
249 Auto-dimming Driver and Rearview Mirrors
264 License Plate Holder
275 Power Driver Seats with Memory
287 Split-Folding Rear Seats
299 PRE-SAFE®
30P Storage Space Package
310 Twin Cupholders
321 Fingerprint scanner
345 Rain Sensor Wipers
34U Remote Services Premium
351 eCall-Emergency System
355 Extended MBUX functions"
37U Remote Services Advanced
384 Communications module (LTE Advanced) for the use of Mercedes me connec
421 9G-TRONIC 9-Speed Automatic Transmission
461 English Inscriptions
464 12.3" Digital Instrument Cluster
475 Tire Pressure Monitoring System
494 USA specification
500 Power Folding Mirrors
517 HD Radio
521 MBUX multimedia system
543 Double Sun Visors
551 Anti-Theft Alarm System
580 Dual Zone Climate Control
608 Adaptive High Beam Assist
632 LED Headlamps
634 Omission of first-aid kit
636 Omission of Warning Triangle
668 Sea Packing & Dispatch
677 Lowered Comfort Suspension
757 Piano Black Lacquer Center Console
75B USB package
803 Technical modifications
852 Advanced Alarm with Parking Collision Detection
868 12.3" Center Display
876 Premium Interior Lighting
881 Electronic Trunk Closer
887 Independent Trunk Locking
889 KEYLESS-GO®
01.17.2023 06.22.24
891 Multi-Color Ambient Lighting
893 KEYLESS-START
916 Large Capacity Fuel Tank
94B Integrated Starter Generator Generation 2
986 Identification label with VIN number
989 VIN Code
B01 EQ Boost 48V System
B59 DYNAMIC SELECT
L3E Multifunction Steering Wheel
P14 Standard Interior
P15 Standard Exterior
P49 Mirror Package
U10 Passenger Seat Weight Sensing System
U12 Floormats
U22 4-Way Lumbar Support
Options
DA3 Parking Package $1,000
235 PARKTRONIC with Active Parking Assist
501 Surround View Camera
P47
P82 URBAN GUARD vehicle protection Plus
DX1 Exclusive Line
239 Active Distance Assist DISTRONIC® $600
401 Heated & Ventilated Front Seats $450
413 Panorama Sunroof $1,000
4B8 USB adapter cable
51U Black Headliner
536 SiriusXM Radio with Free Trial Period $350
587 Side Mirror Logo Projector
783 Radio remote control with panic switch
7U2 Seat Type 2
894 Enhanced Ambient Lighting $250
H04 Natural Grain Black Wood w/ Aluminum Lines $200
R02 All Season Tires
R66 Extended Mobility Tires
R86 18" Multispoke Wheels
U01 Rear belt status indication in the instrument display
U25 Illuminated Door Sills $150
D10 Rear Spoiler, Body Color $350
D49 First Aid Kit $35
D6G Tracking Code Custom Options 2
D9B Credit for Missing Standard 871 Hands-Free Access
2023 W206 C300
Reply 0
Nov 15, 2025 | 05:24 AM
12B Owners Manual
16U Apple CarPlay™
17U Android Auto
299 PRE-SAFE®
310 Twin Cupholders
517 HD Radio
632 LED Headlamps
75B USB package
889 KEYLESS-GO®
01.17.2023 06.22.24
893 KEYLESS-START
989 VIN Code
B59 DYNAMIC SELECT
P49 Mirror Package
U12 Floormats
Options
P47
DX1 Exclusive Line
51U Black Headliner
7U2 Seat Type 2
2023 W206 C300
Even if you install the OEM hardware inside the cupholder area for the charging pad, beware that it might not work until MBUX/computer is programmed to enable this functionality. When wireless charging or NFC pairing occurs (like for the mobile key), icons are displayed in the central screen which indicates some data transfer between the charger and car computer. I am not sure if it plug and play, so some advice to keep in mind.
Digital key is only available on 2025 and beyond C models. https://moba.i.mercedes-benz.com/bai...US/index.html# You're not missing out though. Digital key is not yet available in c and glc models in the USA, it keeps getting delayed. Some have had luck with getting their dealer to update MBUX which unlocks a digital key menu in the car, but the mobile app does not yet support pairing so it's useless.
Reply 0
Nov 15, 2025 | 04:18 PM
Thanks 818!! I figured there would be some sort of programming. Digital key would be a nice back up but isn't essential for me. If I find the OEM module on a deal, I'll probably grab one but I'm definitely not in a rush.
We're neighbors, I think in the SFV!
Reply 0
Dec 17, 2025 | 02:41 PM
No, it won’t. Smart phone key require a dedicated module(A000 900 7350) and an MY25 gateway/electronic ignition. Three additional antenna located in A pillar and rear pillar. And you need the option code 896, so Mercedes Me app will realize you car have mobile key and allow enrollment.(and btw, adding permanent option code is NEAR impossible right now unless you have solid connections)
you may or may not need a new driver door handle that support NFC as well.
the above is in theory from me reading the WIS and EPC.
Now in practice, I have added OEM wireless charging pad to my car and have it programmed via SCN(which means permanent option code 897 was also added) and simply doing this added nothing.it support pairing Bluetooth to car via nfc, that’s it.
I have bought all the parts for my MY23, and was planning on attempting a retrofit, but the commitment is very very real. Basically have to rip the entire interior of the car apart and run a bunch new wires, not for the light hearted. To me it’s worth it because in my mind mobile phone key is the difference between a 2015- car and a 2020+ car. MB should have shipped w206 with mobile phone key at the first model year.
Reply 1
Subscribe
Currently Active Users (1)
