C-Class (W206) 2021 to
How to change Max Volume
Old Nov 30, 2025 | 12:02 PM
Steely's Avatar
C300 W206 2022
I primarily use USB as a music source and the volume maxes out at relatively low levels. I remember coming across a post that showed how to increase this max volume limit but I cannot find it now when I search. I think it was in the service menu. Any guidance is appreciated.
Old Nov 30, 2025 | 06:45 PM
818benz's Avatar
2025 C300
Go to settings. You will see headings for the different menus. The first one should be assistance. Repeatedly press the assistance title 8-10 times until the dealer menu pops up. From there you can adjust the comfort volume min and max values by dB.
Old Nov 30, 2025 | 08:33 PM
olddude's Avatar
C300
Be very careful messing with the Dealer's Menu. It shouldn't hurt to play with volume but beware of the other settings. These are not areas you want to change unless you really know what you are doing.
Old Dec 1, 2025 | 04:02 AM
818benz's Avatar
2025 C300
Agreed, leave any settings you're unfamiliar with untouched. Search or reach out again if you have questions!
Old Dec 1, 2025 | 01:33 PM
Steely's Avatar
C300 W206 2022
Worked like a charm...thanks!
TracerMerc's Avatar
W206 220d
I found this menu, but didn't notice any improvement after increasing the volume.
Old Dec 14, 2025 | 06:16 AM
818benz's Avatar
2025 C300
Which settings did you adjust in the dealer menu? Pls send them as well as dB change values.
