C218 CLS63, 2011 - 2019
2012 homelink
Old Feb 5, 2012 | 10:06 PM
XRAYAMG's Avatar
14 SLS Black Series, 09 SL65 AMG Black Series, 15 G63 AMG, 15 Ferrari Speciale, 16 GTR Nismo
2012 homelink
i'm having difficulty programming my homelink. i have had many other mercedes without problems. anyone else have issues?
Old Feb 5, 2012 | 10:34 PM
XRAYAMG's Avatar
nevermind. found new instructions on c218 forum. different from previous and instructions in manual.
Old Feb 6, 2012 | 02:39 AM
vdubpower's Avatar
i drive them all, fast and hard
i still cant get mine to work, i have a chamberlain garage,
how did you get yours to work
Old Feb 6, 2012 | 09:15 PM
XRAYAMG's Avatar
I'm not taking credit for this. Got this off c218 forum. Worked for me.
2012 CLS Homelink Instructions
Had a time programing the Garage opener. Had to call homelink and get these instruction. The directions are a little different than what is in the handbook.
1. With the vehicle ignition in the ON position, press and hold the desired HomeLink button until the indicator light turns yellow.
2. Release the HomeLink button. The indicator light will continue to flash yellow.
3. Hold the original handheld transmitter for the gate or garage door opener (or other device) that you wish to train within 3 inches of the HomeLink button. Press and hold the button on the remote until the HomeLink indicator light turns green, either solid or flashing.
4. Release the handheld transmitter button.
5. If the HomeLink indicator light is solid, HomeLink should operate the door and programming is complete.
6. If the HomeLink indicator light is flashing, press and release the “learn” or “smart” button on the garage door opener receiver (motorhead unit).
7. Return to the vehicle and press, hold for 3 seconds, and release the trained HomeLink button. Perform this process up to three times.
8. The device should operate with the HomeLink button and programming is complete.
Clearing the HomeLink buttons:
1. With the vehicle ignition in the ON position, press and hold the 2 outside HomeLink buttons. The light will illuminate yellow, then change to green after several seconds. Release the HomeLink buttons. The buttons are now erased.
