C218 CLS63, 2011 - 2019
Which race fuel?
Old May 13, 2012 | 05:37 PM
JumpinJim's Avatar
SL63
Which race fuel?
With all the talk of the tuned TT engine blowing up I was thinking of running race fuel when I go to the track next time in mine. Obviously I'll want unleaded fuel, but then there's oxygenated vs non-oxygenated. I hear that oxygenated race fuel can make an engine run leaner which is to be avoided unless tuned for it. Would I take it I would want to run an unleaded non-oxygenated fuel then? Or will our cars and the renntech tune I have not care about oxygenated fuel? I notice that most unleaded race gas is of the oxygenated variety.
Old May 14, 2012 | 02:41 PM
_AMG_'s Avatar
C63
Oxygenated fuel uses a blend of ethanol were non-oxygenated is pure gasoline.
Just go with some MS109.
Old May 14, 2012 | 02:48 PM
BenJ's Avatar
2003 E55 AMG
VP MS109
Old May 14, 2012 | 02:55 PM
hyperion667's Avatar
2012 CLS63
Cool (jk!)
don't forget about this one too
Old May 14, 2012 | 03:43 PM
JumpinJim's Avatar
SL63
What the.....
Old May 14, 2012 | 04:44 PM
JumpinJim's Avatar
SL63
Interestingly in the Porsche forums some shy away from MS109 as they say it runs much leaner, about a full point leaner than pump gas. I've run TrackTek 105UL in my 911 Turbo and it ran very well, however the tune in it is adjusted for 100 octane race fuel. I've asked Renntech about the CLS 63 tune and they indicated it was tuned for 93 pump gas. I've been doing some research on what race fuel has a similar oxygen content, specific gravity, and stoich to pump gas to keep everything happy.
Old May 15, 2012 | 02:43 PM
JumpinJim's Avatar
SL63
Here's the reply I got from RennTech.
We suggest running only non-oxygenated unleaded race gas and between 100 and 104 octane. The specific gravity of the race gas is heavier, but the variance is much less that the variance caused by the use of (hydroscopic) ethanol to augment regular pump gas. The pump gas can vary greatly simply based on how much water the ethanol has consumed.
That would exclude MS109 as it's one of the most heavily oxygenated unleaded race fuels out there.
Old May 16, 2012 | 02:31 AM
_AMG_'s Avatar
C63
So which specific fuel does Renntech recommend?
Old May 17, 2012 | 10:16 AM
JumpinJim's Avatar
SL63
They didn't suggest any specific brand, just specs. Will have to do some homework to figure out which to use.
Old May 22, 2012 | 03:44 AM
kohjul's Avatar
AMG
Sorry to ask in this thread but since you guys talking about fuel, I want to know what is the best gas company in socal that I can use in tuned cls? Chvron? Shell?
Old May 22, 2012 | 01:26 PM
Saeedg48's Avatar
2009 CLS63 AMG
MS109
Old May 22, 2012 | 02:10 PM
freefall's Avatar
2012 C63 Purpose built race car, 2015 CLS 63 S, 2016 GLA45, 2017 GTS
What is MS109?
Old May 22, 2012 | 09:17 PM
_AMG_'s Avatar
C63
I see, hope Renntech chimes in and says which one they recommend.
I used to buy MS109 in 5 gallon drums from Manning Fuel in Sun Valley, CA.
Give them a call.
http://www.manningfuel.com/
Originally Posted by freefall
What is MS109?
MS109 is 101 octane unleaded/oxygenated race fuel supplied by VP Racing.
Old May 22, 2012 | 09:24 PM
BenzoBoi's Avatar
Super Moderator
W221
Another vote for VP MS109.
Old Jun 1, 2012 | 03:08 PM
JumpinJim's Avatar
SL63
After more discussions either Track Tek(Chevron) 105 or Shell URT 110. Shell for the better anti knock running high boost in the TX heat. Otherwise the Track Tek 105 is perfect. Neither are heavily oxygenated. Price difference is about $80 between the two for a 55 gallon drum, the 105 being cheaper. I ordered a drum of Shell URT 110 for $670.
Old Jun 1, 2012 | 03:24 PM
_AMG_'s Avatar
C63
Where did you order the Shell race gas from?
Old Jun 1, 2012 | 03:27 PM
JumpinJim's Avatar
SL63
Motorsport Sales in Dallas.
Old Jun 1, 2012 | 07:56 PM
freefall's Avatar
JJ - Renntech tunes are made for 93 oct. Any issues going to 100?
Old Jun 2, 2012 | 06:35 AM
JumpinJim's Avatar
SL63
No, in fact it's recommended if you're going to be running the car hard at the track for extended periods. Note you won't pick up any power, but it will be safer. Higher octane race gas has much better anti knock and detonation properties.
Old Jun 6, 2012 | 03:00 PM
JumpinJim's Avatar
SL63
Now that's what I call a barrel of fun!
