C218 CLS63, 2011 - 2019
CLS 63 curbed wheel repairs, best place?
Old 12-19-2012, 03:25 PM
fixinbones's Avatar
2016 AMG GTS, 2015 GLA45 AMG
So my wife has managed to curb all four of the wheels on her CLS63. I would like to have them repaired over the winter as I put on a set of snow tires with CLS550 rims. Can anyone tell me where the best place to send them for repair is? FYI, I am in NY.
Old 12-19-2012, 04:05 PM
vdubpower's Avatar
i drive them all, fast and hard
theres probably a few mobile companies that do nice jobs....
btw, are u an orthopod
Old 12-19-2012, 04:09 PM
fixinbones's Avatar
Thanks, and yes, I am an Ortho.
Old 12-19-2012, 05:14 PM
komp55's Avatar
ML550
If you seek high quality repair work, look no further than:
http://wheelcollision.com
Old 12-19-2012, 05:18 PM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
USA Wheels in Fairfield, NJ
Old 12-20-2012, 03:19 PM
fixinbones's Avatar
Thanks for the info guys!!!!
Old 05-14-2013, 05:58 PM
slk55er's Avatar
'19 CLS53, '19 SL550, '22 GLE53
Or Try A DIY Project:
Dupli-Color Silver Caliper Paint (BCP103)is a nearly perfect match and it provides a gloss finish without a separate clear coat. You can likely buy it at your local AutoZone, O'Reiley or Pep Boys.
Here's what I do for all my MB rims and recommend:
1) File the rash to eliminate high spots.
2) Fill the valley low spots with a metal patch like "Devcon Metal Patch & Fill" that you can buy at your local hardware store. Sand with wet/dry sand paper (400 or so.)
3) Mask the area with masking tape and newspaper.
4) Apply a light coat of gray primer. Sand with wet/dry (1000 grit)
5) Spray several very light coats of the Caliper Paint. (Too heavy of a application may run.) You can feather the Caliper Paint onto the whee spokes and it will blend in nicely.
6) If you'd like an even more highly reflective finish, polish it with a light cleaner/polish or swirl remover from your local auto paint store.
7) Finish with some good auto or wheel wax.
If you'd like a higher gloss clear coat, you can use Dupli-Color Clear Engine Enamel (DE1636.)
I believe you'll be pleased with the results, particularly considering the low cost. I've tried the Wurth products and have been very disappointed in both the color match and the finish.
Quick Reply: CLS 63 curbed wheel repairs, best place?
