C218 CLS63, 2011 - 2019
Adaptive transmission reset
Old Jul 21, 2013 | 11:44 PM
blacklightus's Avatar
CLS63 AMG
I'm confident that many members know this already, but I recently did a reset of the adaptive transmission. Wow what a difference it makes. I am positive that my granny style driving during the break-in did not help.
Anyway after the reset, I am enjoying the car much more. I had a dodge viper before so was used to > 500hp/tq+, but could not understand why the car would not kick down the gear box and stayed in 4th during open throttle. Now on the freeway, it will kick down to 3rd and accelerate much harder.
I did the research when someone mentioned their improved acceleration after their cls63 was sent in to its first service and the mechanic disconnected the main battery, which caused the adaptive transmission reset. I learned that the older way of flooring the gas pedal for 5 seconds with the key in the on position then turning the key to off and removing my foot of the gas, and waiting 2 minutes works to reset it.
All in all, I was very close to selling the car because I thought something was very wrong, but now I see what everyone is talking about. Car is amazing.
Old Jul 22, 2013 | 12:55 PM
emericr's Avatar
2021 Porsche TTS
I think you may have posted on the wrong forum.
Is this reset on a W218 or W219?
Old Jul 22, 2013 | 01:10 PM
Vic55's Avatar
Administrator
You are right bro--- the W218 can not do the adaptive tranny update,
You can do a hard ecu update but that involves disconnecting the battery.
Old Jul 22, 2013 | 01:31 PM
CLS63 AMG
Okay then I must be confused, sorry. I do have a W218 and felt a difference through the older way of resetting, but read a W218 member mention the reset through the battery. Now I have to try the battery disconnect just to be sure.
Old Jul 22, 2013 | 02:24 PM
Vic55's Avatar
Administrator
The battery will do it but its just too much work and you lose your memory and other things.
On the older models it was a key in the ingintion process that did the reset.
Old Jul 22, 2013 | 09:29 PM
JAN8OR's Avatar
2015 S 63 AMG 4Matic
Hi Vic
What other things would you lose when disconnecting the battery (besides losing radio channel memory)?
Just curious because I just disconnected the battery on my MY12 ML63 to remove the ECU.
Vince
Old Jul 23, 2013 | 01:08 PM
Vic55's Avatar
Administrator
Originally Posted by JAN8OR
Hi Vic
Vince
It depends on the car I would guess... Ive never done it intentionally and cant remember the last time I had a battery issue on one of my Benzes.
Old Jul 23, 2013 | 05:50 PM
emericr's Avatar
2021 Porsche TTS
I did not disconnect the battery when I pulled my ECU on my C63 to send for tuning.
Is it a necessary step?
Old Jul 23, 2013 | 07:47 PM
Vic55's Avatar
Administrator
No not at all--- my tuner on my M157's just made sure the car was completely off and waited a few minutes for the ECU to clear.
Old Jul 24, 2013 | 10:09 AM
emericr's Avatar
2021 Porsche TTS
That is what I thought. Thanks for confirmation.
Old Sep 10, 2013 | 05:21 AM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
I just pulled my ECU out. Pulled the start stop button out, turn key on 1min. then off. Removed key.
Let set for 2 min. Remove ECU.
Replacement, connect ECU, place key in on position, let set for 2 min.
Start.
