Alpha Series Mercedes-Benz 5.5L BiTurbo Downpipes
The Alpha Series Mercedes-Benz 5.5L BiTurbo Downpipes for your E63/CLS63 AMG are the ultimate solution for improving power, throttle response and exhaust note without sacrificing quality, fitment or design. If you are looking for the highest quality downpipes for your M157 engine look no further!
Designed To Out Flow The Competition
Each Alpha BiTurbo Downpipe runs 3” (76mm) tubing for optimum flow all the way to your factory or aftermarket cat-back exhaust. Our competitors chose to mimic the factory passenger side piping where it necks down at the connection creating turbulence and hurting exhaust flow and power. This is a more cost effective way to make the system connect to the cat-back portion of the exhaust but it hurts flow by creating a bottle neck in the system. This is not a compromise we were willing to make so our Engineering team implemented a ball-joint style connection retaining a full 3" diameter maximizing your power gains. On our test vehicle +30HP and +35ft-lbs were seen on the cat-less version!
Unparalleled Fitment Through Proper Engineering
The BiTurbo downpipes aren't something we quickly whipped up in a fabrication shop. These are properly designed and engineered using a CMM Laser Scanner for a perfect fit and space optimization. By choosing a 3 piece design we've provided improved adjustability and fitment making them easy to install. We also took the time to integrate the factory O2 sensors, heat shielding and brackets for a clean and proper OEM-like installation. When you chose Alpha there is no need to hack up your prized possession.
The Difference Is In The Details
Another unique benefit is our GESi racing catalytic converter option. These 300 cell count units provide nearly no disruption in flow and feature a staked in design to hold the catalyst firmly in place. Many competitors offer a low quality converter option to keep the cost low and profits high. Often these units fail due to poor construction and inferior materials. When you choose Alpha you will remain emissions compliant and worry free for years to come.
Do it right the first time, order your Alpha Series BiTurbo Downpipes today!
Exclusive Benefits
Exclusive Benefits
- Big increases in power throughout the entire power band
- 3" (76mm) piping all the way through to the cat-back connection
- +30HP and +35ft-lbs gain over stock downpipes (non-catted)
- +15HP and +15ft-lbs gain over stock (catted)
- Improved turbo & throttle response
- Eliminate turbo lag
- Exotic exhaust note
- 3 piece design for precise and proper fitment
- Retains factory heat shielding
- Premium race catalytic converters
- Mates up to stock and aftermarket exhaust systems
- Unrivaled fit and finish
- Includes ALL necessary parts and hardware for installation
- 100% low carbon 304 Stainless Steel construction
- 3" (76mm) piping with .065" wall thickness
- 300 cell race catalytic converter (optional)
- W212 2014+ Mercedes-Benz E63 AMG 4Matic
- W212 2012-2013 E63 AMG (RWD)
- C218 2014+ CLS63 AMG 4Matic
- C218 2012-2013 CLS63 AMG (RWD)
Also be sure to check out our full exhaust system too: http://www.amsperformance.com/cart/2...st-system.html
nice product but no offence almost 3k for it?? MBH same exact thing 1k less I don't see how it could be such a big difference. but anyways
MB tax even worse under 0bama I see...
Quote:
Our pipes are not the exact same. We have a three piece V-band design which is critical because when moving to our turbo outlet pipes in the future you will be able to swap out that top section and have a full 3" system with no reducer at all. with our pipes you can also swap between catted and non catted by changing that top pipe only. Our pipe is about $700 more which I think is worth it for that option.Originally Posted by berti_00
Eric
Quote:
Eric
So Turbo outlet pipes are on the way?? Then Iguess the system woule be similar to Weistec.Originally Posted by AMS_Performance
Our pipes are not the exact same. We have a three piece V-band design which is critical because when moving to our turbo outlet pipes in the future you will be able to swap out that top section and have a full 3" system with no reducer at all. with our pipes you can also swap between catted and non catted by changing that top pipe only. Our pipe is about $700 more which I think is worth it for that option.Eric
Turbo outlet pipes are indeed on the way but we wanted to develop a pipe for people that didn't want to go through the arduous task of dropping the engine to swap the turbo outlet pipes. We also didn't want to ask people that wanted to do that to buy a whole new set of downpipes. This was a nice compromise without sacrificing any performance.
Eric
Eric
