285-30 & 245-35 on 20s?
ive seen 255 35 20 and 295 30 20 on the black weistec car,
they used their own springs up front and let the car adjust it self in the rear, as far as i recall, that was an e63 tho...u can likely go wider on the cls due to offset
Your tire diameters are the same as OEM, hence the large fender gaps you still have. The OP is looking to close the gap with a larger than OEM tire diameter, like I used.
