Brake Upgrade?
There is a thread discussing about a brake upgrade kit for CLS550 here:
https://mbworld.org/forums/cls-coupe...e-package.html This upgrade BBK is under development and the availability will be announced in about two weeks. Would any CLS owner be interested in upgrading your brakes?. |
CLS400 has a small brake with floating calipers (front and rear), and shares the same spindle as CLS550 so the same BBK in development can be an excellent upgrade for both 400 and 550.
Our brand new CLS550 project car just purchased from Flectcher Jones in Newport Beach, CA
It has Metallic Black body with tan interior: https://cimg8.ibsrv.net/gimg/www.mbw...b8317f98ff.jpg https://cimg0.ibsrv.net/gimg/www.mbw...f1e2ca6f89.jpg https://cimg2.ibsrv.net/gimg/www.mbw...fba0e67566.jpg |
Heavy front rotor (360x36mm) wt=33.5 lbs
https://cimg9.ibsrv.net/gimg/www.mbw...8260c5a259.jpg https://cimg7.ibsrv.net/gimg/www.mbw...748940c742.jpg Drill holes got all clogged up after only 120 miles https://cimg1.ibsrv.net/gimg/www.mbw...85b23de00a.jpg https://cimg2.ibsrv.net/gimg/www.mbw...8b3abfdd5e.jpg Dusty wheels - Very noticeable even MB makes the barrel in gray color https://cimg9.ibsrv.net/gimg/www.mbw...f25f0f390d.jpg https://cimg0.ibsrv.net/gimg/www.mbw...9d8f212bfd.jpg |
Caliper (Front) w/o pads:
https://cimg2.ibsrv.net/gimg/www.mbw...f8384b9804.jpg Caliper loaded with pads https://cimg2.ibsrv.net/gimg/www.mbw...4e3aedd925.jpg Brake pad: https://cimg8.ibsrv.net/gimg/www.mbw...41b8c82aed.jpg This RB pad pin punch makes pad removal a snap. https://cimg1.ibsrv.net/gimg/www.mbw...e8855ca263.jpg https://cimg5.ibsrv.net/gimg/www.mbw...67c1833212.jpg |
SL550 brake check up
https://cimg4.ibsrv.net/gimg/www.mbw...d840b1313a.jpg Pad hold down spring removed https://cimg2.ibsrv.net/gimg/www.mbw...6b3385c5dd.jpg Wear sensor wire disconnected https://cimg4.ibsrv.net/gimg/www.mbw...d1b2f035a8.jpg Brake set up with wheel removed https://cimg6.ibsrv.net/gimg/www.mbw...61c17e515c.jpg |
Great check-up..:y
ZAYED,, |
Why we selected CLS for brake development? - It was motivated by CLS Customer - Chris who has been so persistent that leaded us to this...
Originally Posted by CLS Custom
(Post 6793940)
I purchased my CLS because I wanted a big, yet powerful full-size luxury vehicle, that was still agile and sporty while providing comfort and safety. I love it so far, and it has certainly surpassed my expectations.
The all-wheel-drive is phenomenal, and the car drives, handles, and accelerates like a small sports car while being a full-size premium sedan. The car is great from the factory, but being that it is so big and heavy, yet so powerful and offers so much performance, that the factory brakes can become taxed easily. This is the only aspect of the vehicle that leaves something to be desired. The stock brakes are the Achilles heel, of an otherwise surprisingly superb vehicle. By upgrading the factory CLS brakes to the custom Racing Brakes package we are putting together, I hope to transform the vehicle to have perfect attributes. The increased braking performance will provide confidence under both normal and spirited driving, and positively affect all aspects of driving dynamics. The CLS will have its one and only problem solved! Upgrading the brakes of the CLS won't only make it a better and more rewarding car to drive, but will also make it a far more safe vehicle to drive. It's a win-win upgrade! I am sure we have all felt the weakness of the stock setup during spirited driving, and surprise stops. The car is simply too heavy and accelerates too quickly for the stock brakes. An upgraded big brake kit will certainly make the car much safer, which is of huge importance to me. Confidence under braking is the only thing missing; I can't wait for this upgrade! Oh, and this big brake kit is noticeably lighter than the stock setup, which will reduce unsrung mass. So, this brake kit will make the car quicker and handle better too....I guess that's a win-win-win lol Please follow this thread for further update. |
completely agree,
i put the same Front 4-pot set-up in "W210", from "2012 Cls550" 6 months ago, they're Extremely heavy/much heat/more dust..!:mad:!, not sure why MB still using these brakes with their many models from 2006 till now..!!?:nix:?!! these nice MB's should to have lightweight calipers with 2-piece Rotors..:rolleyes: ZAYED,, |
The other reason we like CLS is it still retains the traditional rear drum brake as emergency (or parking) brakes.
Unlike most of other newer models (including all "S", GT S and ML63) are now equipped with electro-mechanical rear brake, which essentially is a traditional floating caliper w/an actuator to activate (push the pad) for parking. Not only they are ridiculously small in look and performance comparing to the front (like some huge 6 pot) but it also means if a hydraulic system is ever failed the parking (or emergency) function is also disabled. https://cimg7.ibsrv.net/gimg/www.mbw...e4c67b6d85.png Cars come with "independent" mechanical rear drum brakes not only is sound and safe but also facilitate easy upgrade to BBK with a caliper adaptor (below), to relocate the caliper (while the rear E-brake remains intact) but not those come with electro-mechanical rear brake. https://cimg9.ibsrv.net/gimg/www.mbw...b92082cd62.png |
Front stock one piece rotor (360mm, 33.5 lbs) and stock 4 pot gray caliper behind the wheel:
https://cimg8.ibsrv.net/gimg/www.mbw...55764b57ba.jpg RB two piece rotor (390mm, 28 lbs) and 6pot red caliper behind 19" MB wheel: About 4mm clearance https://cimg6.ibsrv.net/gimg/www.mbw...34a1c0f218.jpg Rear BBK (360mm rotor) will be fitted with picture shortly. Meantime here are stock set up. Rear stock rotor (320mm) w/stock floating caliper: https://cimg9.ibsrv.net/gimg/www.mbw...753fb7c50d.jpg https://cimg0.ibsrv.net/gimg/www.mbw...6b5819904d.jpg |
Red 6 pot caliper (w/o pads):
https://cimg3.ibsrv.net/gimg/www.mbw...80112dcddb.jpg With pads: https://cimg4.ibsrv.net/gimg/www.mbw...90acb4f80a.jpg Weight comparison: Stock set up 360x36mm 1 pc rotor and 4 pot stock caliper: (33.5 lbs + 14.67 lbs) x 2 = 96.4 lbs RB set up 390x36mm 2 pc rotor and 6 pot upgraded caliper:(28 lbs + 14.3 lbs) x2 = 84.6 lbs Total weight saving on front axle: 11.8 lbs (even with larger rotors and 6 pot calipers) |
Might want to check your math...
Weight comparison: Stock set up 360x36mm 1 pc rotor and 4 pot stock caliper: (33.5 lbs + 14.67 lbs) x 2 = 96.4 lbs RB set up 390x36mm 2 pc rotor and 6 pot upgraded caliper:(28 lbs + 14.3 lbs) x2 = 56.3 lbs Total weight saving on front axle: 40 lbs (even with larger rotors and 6 pot calipers)
Or who knows, maybe it's right using Common Core"...
Weight difference corrected. 40 lbs saving would have been for CCM rotors for an estimated weight of 13.4 lbs/ea. Saving 20 lbs each over stock 1pc iron.
:y
CLS rear brake with emergency drum brake.
https://cimg0.ibsrv.net/gimg/www.mbw...6ab5b04601.jpg Drum brake shoe adjuster. https://cimg1.ibsrv.net/gimg/www.mbw...9d7f801342.jpg This is how RB rear two piece rotor hats are made - With an iron sleeve for brake shoe so it's light weight (aluminum shell) yet retains the OE brake integrity for drum brake. Most aftermarket rear two piece rotors are machined from aluminum only; without this e-brake provision like ours. So it's your protection to check the supplier before you buy. https://cimg8.ibsrv.net/gimg/www.mbw...2ac8433a62.jpg |
Originally Posted by chiromikey
(Post 6806591)
lol common core |
Any CLS owners have comment on their brakes?
These hand brake shoes looks the same with previous "W219>>W218" with (180x25), isn't..?!?
ZAYED,, |
Yes, it's 180mm drum shoe.
Thankss for reply,
I may think it's more easier to upgrade brakes with mechanical shoes, rather than Electrical shoes..?!? ZAYED,, |
Absolutely correct. As the drum emergency brake is independent to the primary hydraulic brakes so one can always use E-brake if hydraulic system ever failed, unlike electrical mechanical one that tie together.
Excellent info., Thankss a lot..:)
ZAYED,, |
Test fit front BBK with red 6 pot caliper and 390x36mm RB two piece rotors:
The prototype adaptor is made, and fitment is as expected with perfect alignment with rotor edge and centering around caliper. https://cimg9.ibsrv.net/gimg/www.mbw...a392a1e3ec.jpg https://cimg1.ibsrv.net/gimg/www.mbw...ee7b2f9bbb.jpg https://cimg8.ibsrv.net/gimg/www.mbw...28e4ba8b3a.jpg Link to front and rear BBK w/OE calipers. http://www.racingbrake.com/Mercedes-.../mb-irk-25.htm Note the picture doesn't show front calipers but they were included (see contents description). Once you upgraded to this kit your brake will be even bigger than CLS55's or CLS63's although with the same calipers as theirs. |
