top end falls off (before and after) dyno tune. looking for suggestions...
from those vids Boost looks fine, IAT's look fine, The timing is way off. Not sure where you're located but need some good fuel in it and run again. Only way to know for sure is get a gallon of race gas and mix with 93 (1/4-1/2 tank depending on race gas blend available), you can also see who sells Torco in your area. It works really well has mixing instructions on the bottle. Another option would be "octanium" which is an additive made by VP. They sell it at Autozone in the US. Its pretty much like the Torco I mentioned above. Try one of those options and report back the timing up top. There are many other factors that could kill timing but try the simplest first which would be fuel quality. Logging apps depending on your device are Torque, Dash Command, Blue Driver are a couple that export a .csv log file. you will need to order a OBD Dongle to connect. They are cheap can get on Amazon. PC option thats cheap is TOUCHSCAN. You will need a wireless dongle for that one as well. Let us know!
Porsche 991 GT3, 2012 cls63 Kleemann K3
ya im not messing with the gas.
thats not the problem. i use the same gas as all the tuners advertise and they dont claim race gas is needed for their gains.
does it look like the transmission is slipping in this pull?
i thought it was traction control cutting in at the time. but not sure.
Aside from the fuel quality I would look into false knock retarding the timing. If you can log Fuel trims that may tell a tale of a lean issue causing the timing to lower. I will try and find some of my stock logs and see what the timing is at across the board. Being tuned they should be a bit higher if not just more consistent across the RPM range
https://www.youtube.com/watch?v=-3S3RwkrWkU
#32
Doesn't look like its slipping just looks like it was low in the rpm so the clutches disengaged for a second to get revs up the engaged again. Kind of like what you would do in a manual transmission. I wonder if possibly torque management is killing your timing? I am not familiar with the tuning maps/tables on the Mercedes but I know on GM stuff you can pull timing for toque management. The TM seems to be an issue when the HP gets over 700 on our cars in the US but overseas they seem to turn it off or something.
thanks. so im basically at a loss.
this car is essentially a taxi now. unless i can get to the bottom of this.
i wish there was somewhere in Canada i could ship the car to and say here. "make it trap 130+ mph".
left lane
#33
honestly, call Eurocharged Canada in toronto, speak to Ben or vlad. They will certainly be able to help you out as they have tuned MANY of these cars with great results (126-128mph traps).
#34
Can they rebuild transmissions because I'm.thinking thats the problem along with needing a turbo upgrade.
#35
not every Eurocharged shop does exactly the same work and use exactly the same files, they are independent.
Did you get the work done at the toronto shop or elsewhere?
they certainly should be able to help you get to the bottom
of it so maybe try contacting them
#36
did you not read my post?
so you didn't read my post.
ok.
as i said already. JERRY from EUROCHARGED PERSONALLY tuned the car.
now please stop responding to my post.
i'm tired of arguing with you.
#37
i JUST finished saying that all the Eurocharged shops are not the same. Eurocharged Canada is not using the same files, not doing the same work in tuning the car as the US.
This is why im suggesting to contact them as they will be able to use their knowledge and do different testing to see what the problem is and likely resolve it as they have done MANY and are more local to you.
Oh well, I guess seeing that your a ***** you got what you deserved. I hope you crash it and move on to a different forum, no reason to help people like you with that attitude.
#38
wow are you illiterate?
listen, the car has been tuned 4 times by 3 different tuning companies. but the problem persists. tuning is NOT the issue.
#39
Doesn't matter the shop has a TON of experience with these cars. You think all they do is tune it and that's it? No knowledge of how to diagnose problems as if that never comes up?
ive personally witnessed them troubleshooting all kinds of AMGs there with various issues that come up and usually they get down to the bottom of it and get the issues fixed.
All i I said was simply give them a call and see if they can help out, nothing wrong with that and they can likely be of huge help.
Anyway do whatever you want I don't give a damn anymore, im out, enjoy your malfunctioning m157.
#40
The assertion that a tuner that has Never seen or worked on my car can diagnose and solve a problem over the phone is literally the most ridiculous thing I've ever heard. You're hereby dismissed from the adult table.
#41
Are you turning traction control all the way off?
Are you power braking off the line or using Race Start?
What mode are you going down the strip?
#42
Is this the only run you have? What are you doing for technique at the track? Those are waaaay off. With your dyno numbers the 60' should be waaay better.
they were clean runs. i usually use sport+., i dont think i ever used traction control all the way off. but i have gone with it all the way off on the street and it doesn't improve the acceleration. at those speeds(110-120 mph) the traction control isnt going to be interfering anyway.
one 60 foot was 1.8 but that run had a slower trap speed. would it?
just basically power braking or using launch control, ive used both.
trust me ive tried everything, but i didnt think any of that would affect trap speed.
#43
all runs were basically the same. i managed 12.0X but this was the highest trap speed.
