C218 CLS63, 2011 - 2019
Tire Size ?
Old Mar 8, 2019 | 03:48 PM
mjohn50n's Avatar
CLS63
Tire Size ?
Just received a set of Vossen wheels 20x9 and 20x10.5. Will lower on KW, can anyone suggest the correct tire sizes for this setup. I was told 245/35/20 front and 285/30/20 rear. I was thinking more 255/30/20 and 285/25/20. Thoughts?
Old Mar 11, 2019 | 05:19 PM
Ericv13's Avatar
2013 C250
way to thin out back ! I currently have 295/30/20 and it’s bad on ruff roads, stepping up to a 295/40/20
Old Mar 11, 2019 | 05:54 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by Ericv13
... stepping up to a 295/40/20
Good luck with that. Just in case you're confused, this is for CLS not ML/GLE.
OP, you should using 245/35-20 with 285/30-20, as you were advised.
Old Mar 11, 2019 | 06:46 PM
mysticblu999's Avatar
Mercedes AMG
No way that's going to fit lowered as that is way taller than stock. If you want the right sizes for 20s its 255/30/20 and 295/25/20. I think you could even squeeze 305/25/20 I am going to try it soon.
Old Mar 11, 2019 | 07:08 PM
Ericv13's Avatar
2013 C250
I still have quite a bit of space to fill right now and I’m on 285/30/20, need something wider and taller.
Old Mar 11, 2019 | 07:11 PM
mjohn50n's Avatar
CLS63
Vossen mentioned a 305/25/20 for the rear, but I believe thats too wide for the look im after. I think you got it right! Thank you!
Old Mar 11, 2019 | 07:56 PM
Mercedes AMG
Stock is 285/30/19 and a 285/30/20 is 1" taller than stock. Please post a pic, I'd like to see it.
Its too wide for a E63 but the CLS63 has a little more room on the back. You can't go wrong with either. Either way, just wanted to stop you from putting the wrong sizes on your car. Post pics when you get it!
Old Mar 11, 2019 | 09:06 PM
threeMBs's Avatar
Stock is 285/30/19 and a 285/30/20 is 1" taller than stock. Please post a pic, I'd like to see it.!
CLS550, not CLS63, but fits for sure if not lowered. (May fit lowered too, but did not try).
255/30&295/25 are rubber bands. 245/35&285/30 have real sidewalls.
Old Mar 12, 2019 | 12:24 AM
Ericv13's Avatar
2013 C250
Old Mar 12, 2019 | 10:49 PM
mjohn50n's Avatar
CLS63
Tire Size?
Old Mar 13, 2019 | 12:44 AM
Ericv13's Avatar
2013 C250
Tire Size?
285/30/20
Old Mar 13, 2019 | 01:39 PM
Mercedes AMG
I mean no offense but, you guys are not lowered and don't have AMGs. You are suggesting him to put a narrower tire on the front than his car has stock? If you guys wanted "real sidewalls" why didn't you stick to the factory size?
This is a 295/25/20 on my E63 that has been lowered. Very similar to the cls63. Hardly rubber bands. I had to raise it up a bit because it rubbed.
Old Mar 13, 2019 | 01:41 PM
Ericv13's Avatar
2013 C250
i have 30 series and need a bit more meat, feel every crack and flaw on the road !
Old Mar 13, 2019 | 02:02 PM
Mercedes AMG
That's really just the nature of them. How much air are you running?
Edit: if you go with that much of a taller tire in the back you are talking about, not only will you have rubbing issues, but you are going to freak out the traction control system with different tire heights from the front and rear.
Old Mar 13, 2019 | 03:08 PM
threeMBs's Avatar
Because what can be fitted on C218, can not be fitted on W212 (I am talking AMGs for both) - you can go significantly wider with lower offsets (and higher diameters) on C218 vs. W212. Yes one can fit wider tires with lower offsets even on non-AMG C218 vs. AMG W212.
If OP is insisting on running 30/25 profiles on 20s, then I would run 265/30-20 with 305/25-20 - both offering more load index and a bit more sidewall.
Old Mar 13, 2019 | 03:24 PM
Mercedes AMG
Agree with you on that, but both the w212 and w218 come with the exact same size stock 255/35/19 and 285/30/19. Its always best to stay close to stock sizing, especially the diameter. The taller you go, the more your speedo will be off.
265/30/20 and 305/25/20 will look sweet, and IMO is probably the best sizing but offset choice here will be crucial when lowered.
Old Mar 13, 2019 | 03:29 PM
threeMBs's Avatar
Yes, absolutely.
Old Mar 13, 2019 | 03:33 PM
Mercedes AMG
Yes, absolutely.
Old Mar 17, 2019 | 12:36 AM
LaunchPad's Avatar
2012 CLS63 PP, Renntech
Whats up with the CLS550 badge? Then the biturbo and AMG badges? Is it a CLS500 that identifies as an AMG?
Old Mar 17, 2019 | 02:16 PM
Ericv13's Avatar
2013 C250
Not sure “what up with it” That’s the way i got it, but i recently debadged it , not really relevant to the post , but thanx for asking 👍🏼
Old Mar 17, 2019 | 03:38 PM
Tomspo04's Avatar
2017 CLS550, 2016 HD Roadglide (120ST), 1972 Super Beetle
��. Great looking car.
Old Mar 17, 2019 | 03:40 PM
Ericv13's Avatar
2013 C250
Thank you 🙏🏼
Old Mar 17, 2019 | 05:29 PM
Gent Shkodrani's Avatar
CLS63 5.5 Biturbo
So what is the propper size for w218 then guys?
Old Mar 17, 2019 | 06:16 PM
threeMBs's Avatar
Define "propper". That's subject to debate by itself.
Old Mar 17, 2019 | 06:19 PM
CLS63 5.5 Biturbo
surely this forum is viewed by many people and someone must have some knowledge regarding the tyre sizes based on their experience, 👀🤞
