C218 CLS63, 2011 - 2019
Exterior door trim
Old Apr 8, 2019 | 10:14 AM
LaunchPad's Avatar
2012 CLS63 PP, Renntech
Exterior door trim
Has anyone ever replaced the piece pictured? IT does right behind mirror Both of mine are damaged. I removed the tweeter however there doesnt seem to be a way to access the screw from behind. Any advice
Old Apr 8, 2019 | 12:53 PM
mschamberger's Avatar
2014 CLS550
No, but I recently put an aluminum overlay over my B pillar because it was delaminating. It looks great. The company provides a 6 piece kit that includes the A pillar trim (the piece you're showing). Here's the company I bought from.
https://www.ebay.com/itm/BLACK-Pilla...72.m2749.l2649
I've had it on for about two months and so far it looks fantastic.
Just FYI.
Old Apr 8, 2019 | 01:51 PM
LaunchPad's Avatar
My B pillars are fine. This piece of both sides has a broken clip. I bought brand new replacements I thought removing the door tweeter would give me access but no luck. I dont want to pull door panel without verifying I have to.
Old Apr 9, 2019 | 09:09 AM
2014 CLS550
I understand your b pillars are fine, I was telling you that the kit came with 6 pieces, including the a pillar corner piece you are asking about. You said both of yours are damaged but didn't specify whether that damage was physical or cosmetic. If it was cosmetic, I had a solution for you, I would have even sent you my left over a pillar corner piece covers since I didn't need them.
Good luck on find instructions on how to replace your corner piece.
Old Apr 9, 2019 | 08:04 PM
LaunchPad's Avatar
Thanks I think I got it figured out.
Old Apr 12, 2019 | 08:07 AM
hyperion667's Avatar
2012 CLS63
Just FYI.
MsB, are you referring to this part? This is driving me nuts!
Old Apr 12, 2019 | 10:07 AM
2014 CLS550
That's exactly what happened to mine. The kit I showed comes w/' 6 pieces, I only used the 2 B pillar ones. They're thin metal with 3M tape and just stick over the OEM pillars. They have a great finish and after 2 months still look perfect. I highly recommend for your situation.
