C218 CLS63, 2011 - 2019
2012 cls63 m157 engine rattle/clattering
Old Feb 4, 2020 | 03:23 PM
Big Boy Toys's Avatar
2012 Cls63 amg
Hi, currently have my 2012 cls63 with m157 motor with 85k on odometer. So i started with with the famous chain rattle on start up. so i had changed the chain tensioners and added the check valves behind tensioners.
so everything was good for about 2 weeks then i started to notice a chain rattle like sound from front passenger side of engine when driving. Only hear noise on deceleration when window is down and you can hear the sound , which is a rattling/clattering sound and seems to go with the rpms. one other thing I notice is the sound going away when the engine oil temp reachs 175 degrees exactly and the no sound even on hard deceleration. Have no CEL light and seem to have no performance change during the period of the rattle.
ive even tested it when i would let car idle and warm up to 175 then drive, then no noise. but when i drive it even at engine oil temp150 you will hear the noise just goes away once engine oil temp reachs 175 or higher. even happens on warm starts when engine oil temp is less then 175.
So what ive replaced already since i know stealership will charge me and arm and leg in labor to just throw these parts at it anyways and im mechanically inclined so i can do these myself.
camshaft adjuster solenoids, check valves, left and right tensioners and have the 4 camshaft sensors on the way.
and not knowing for sure. ive also had people tell me that the cam adjusters themselves are going out. But wouldnt that throw and CEL light since its dealing with the VVT?
next question is has anyone changes or have heard of any noise coming from the Engine variable timing solenoid pressure valve image below that is mount in front of the camshaft adjusters themselves and is controlled by the magnetic cam adjuster solenoid.
so if anyone has had this problem or is having this problem and could shed some light on the topic would be greatly appreciated
