Removing Climate Control Unit
Do I need to remove the leather trim cover out first to expose any screws that might be required to be taken out as well?
I found this video that shows CCU removal from a CLS (I don't think it's an AMG though) where he is prying the unit out from the bottom section pull out tabs.
However, under a separate thread on this forum, a member had mentioned that the leather trim cover just above the CCU needs to be pulled out first to expose two screws.
I am wondering if I do need to take that leather trim piece out first or not???
I tried to do both of the above but haven't been able to remove the unit yet. Maybe I wasn't applying enough force but I didn't want to break anything.
Is there any trick that I should be aware of?
Would appreciate any advice and guidance!!
I was able to remove the CCU after taking out the screws.
Also, my software and hardware numbers did not exactly match, but the replacement unit that I bought seems to be working fine.
