CLS63 boost/power problem
Im having stupid issues in this car , its running TTE900 turbo kit , meth , full downpipes , Meth . Built trans , convertor .. tuned by Ppperformance ..
car tuned on 28-29psi 900hp+ engine power .
Car now into safe mod , codes are P222786 ( dont know whats that is ) and 2 air mass B1 , B2 ..
we i reset codes car goes to peak boost 7-8psi then drop to 2 psi .. disconnect the battery for 20min car then boosted to 12-14psi sometimes 16psi and go back to 10-12psi ..
no leak nothing in the car .. i made a log and saw LT b1 is not reding , B2 is about 0.6 / 0.8 . Shot fuel trims are fine ... low timing too on 13psi its about 10-12” of timing ....
changed all upper sensors in air box , map sensor and still nothing happened....
what do u guys think ?
check your injectors, could have one stuck open.
