C218 CLS63, 2011 - 2019
Wheel rubbering
Old Nov 9, 2020 | 09:42 AM
dustinN's Avatar
09E350, 07E63, 13CLS63
Wheel rubbing
I lowered my car by .75 inch using H&R springs. The gap is about 1.5 finger. To my surprise, I got wheel rubbering sometimes when turning at low speed. My old E63 got lowered by almost 2in without any rubbering. All are factory wheel and tire size, no spacers. Any W218 owner who has same setup has this problem? Thanks.
rubbering: I meant rubbing
Old Nov 24, 2020 | 11:14 AM
dustinN's Avatar
Could it be power steering noise?
Old Dec 10, 2020 | 11:51 AM
hotrodcls's Avatar
cls63,oval and split vw, 50 Ford custom ,63 Riviera and a 35 Ford Phaeton
I think its electric steering . but mine is lowered as well and now the steering wheel as I turn it makes a whinning noise and also turning locked rt or left something is rubbing . Havent had a chance to look yet Ill inform as I do
Old Dec 10, 2020 | 12:08 PM
dustinN's Avatar
For what I've found so far, that rubbing noise at low speed turning comes from the electric steering. Haven't had a chance for the tech to look into the problem yet.
Old Dec 10, 2020 | 12:16 PM
hotrodcls's Avatar
What did you use for lowering ?
I used H&R springs up front and links in rear maybe its the angle of the bejangle lol Its diff annoying I'm looking into KMac to see if alignment changes anything
Old Dec 10, 2020 | 12:45 PM
dustinN's Avatar
I used H&R springs up front and links in rear too. Please report back if you decide to go with KMac but please do some homework first, there were a few complains against KMac.
Old Dec 10, 2020 | 08:02 PM
dustinN's Avatar
I have bigger negative camber in the rear than in the front. The negative camber in the front is not not that bad so I don't think the rubbing noise is because of the angle.
Old Dec 28, 2020 | 08:25 PM
dustinN's Avatar
Nothing is wrong with the electric steering. I reassembled the spring, lubricated the strut mount and the inner rubber. The noise is gone.
