2014 CLS63 AMG Coolant Leak
My car has developed a dripping coolant leak near the front passenger side of the block. I can hear what sounds like a small pump running, and the coolant drops on to something very hot. Probably the exhaust manifold. See attached video. Does anyone know what the most likely cause would be, and what that pump sound is?
'99 CLK/05 E500 WAG
I would recomnend removing the engine cover, and get about eye level to see exactly where's coming from. Flash light would be good too for tracing issue. Definitely hitting the manifold. Also check the level of coolant (once it has cooled down). I would look at youtube, and have your Independent workshop or dealer to fix. Gud luck
R,
2Merks
R,
2Merks
Received 2,039 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Post in the w212 amg forum for more feedback and check out the sticky
https://mbworld.org/forums/w212-amg/...-w212-amg.html
your coolant reservoir may have a crack in it or consider the pipes at the brittle connectors - you're a 2014 and are due for new lines/fittings
2MERKS (04-05-2023)
