View Poll Results: Which drop you like better?
I Like BRABUS drop
5
22.73%
I Like CARLSSON drop
17
77.27%
Voters: 22. You may not vote on this poll
Carlsson / Brabus Lowering Module Comparison...
Old Apr 27, 2005 | 11:10 AM
thearle's Avatar
Perfect pics to show difference... both cars are CLS55's that have 20x11 on 305/25-20 rears. The Carlsson has 255/30-20 and the HRE has 245/30-20 front tires on 20x8.5's.
Carlsson (Ken Rogers)
HRE (RedLineRobert)
Old Apr 27, 2005 | 12:47 PM
adam76's Avatar
2010 599 HGTE, 2009 LP560-4, 2010 Range Rover Sport SC
u cant really compare the drop though, they are both adjustable units, with the Carlsson having much more range of adjustment...its known that the Brabus module will not lower the car as much as Carlssons.
Old Apr 27, 2005 | 01:17 PM
E55 RUSS's Avatar
E55K
Kleemanns has more adjustments then both...but in this case looks like Carlsson is lowered more then Brabus...
Old Apr 27, 2005 | 02:01 PM
adam76's Avatar
it actually doesnt, its the same as Carlsson. if u read that other thread regarding modules, its not 100% correct. do your own research.
Old Apr 27, 2005 | 05:00 PM
lorinserbenz's Avatar
none
I have been debating the various modules, I tried the Eibach on my car and it didnt work. The shop I got it from neglected to find out if it worked on an 05 Sl, come to find out it only works on 03-04's. I d
I spoke with Renntech about the various lowering modules and what they said suprised me. They DO NOT recommend ANY module. They said they have tried ALL of them and NONE performed well. They said they alter the ride quality and risk damage to the suspension module.
I was suprised to hear this from such a respected tuner, but I believe them.
I used the washer method on my 05 E and it worked fine.. The nice thing about using the washers is if the airmatic fails you can return it to stock without the dealer knowing the car was lowered. Unless you have a MB tech install the lowering modules you will have a hard time getting a suspension failure covered under warranty.
I spoke with a few other tuners and all of them recommended the Carlsson module. They said its the only one that has worked without issues...
Old Apr 27, 2005 | 07:45 PM
thearle's Avatar
Brabus Airmatic is NOT adjustable.
Old Apr 28, 2005 | 03:04 PM
none
Yes the Brabus is adjustable, there is small switch on the end of the unit that turns it off, on, or slightly higher than the on postion.
I am not sure how low the Brabus module lowers the car, but I do know it has switch to change the height.
Old Apr 28, 2005 | 07:00 PM
thearle's Avatar
That switch is only present on the ABC version... it is NOT on the Airmatic.
Old Apr 30, 2005 | 05:41 PM
none
oohh my bad
Old May 10, 2005 | 08:58 PM
benzmac's Avatar
1999 ML 430, BMW R1100s
I have been lowering all of my cars with the Star Diagnosis Machine as of lately. I guess the lowering modules are for those who don't have access. Any good tech with a factory tester and a little know how can set it EXACTLY how you want it!!!!
Old May 10, 2005 | 11:05 PM
adam76's Avatar
can they also disable the feature where the car lowers itself at high speeds?
Old Oct 3, 2006 | 06:45 PM
steimann's Avatar
CLS550
i have been wondering the same thing! i dont want to be cruising at high speeds and have my car lower onto my tires and mess everything up. did you ever find the answer to this question?
Old Oct 3, 2006 | 07:27 PM
paul928's Avatar
04 E 500 4matic wagon; CLS 63 AMG
Question
According to Cory, the Kleemann module will not interfere with the "speed lowering" feature. I have a Kleemann lowering module and have had no problem with rubbing,etc., when the car hits the "lowering speed".
