sound system in the cls55
Old May 5, 2005 | 04:54 PM
rpabla's Avatar
06 CLS55
in my cls, the sound system doesn't seem that high at all. im thinking that all the speakers aren't working. it tried changing the options but no luck. my s600's sound sysem sounds 10 times louder. maybe i should go to the dealer and test the other cls' systems. anyone else have this problem?
Old May 5, 2005 | 04:59 PM
adam76's Avatar
2010 599 HGTE, 2009 LP560-4, 2010 Range Rover Sport SC
r u sure the Logic 7 mode is selected??? assuming u have the HK system...
Old May 5, 2005 | 05:30 PM
rpabla's Avatar
06 CLS55
yea i am in Logic 7 mode and i do have the hk system... heres an example.. i can hear the seat buckle chime while my sound system is turned up all the way...
Old May 6, 2005 | 07:42 PM
swisstrader's Avatar
Spyker C8, MB ML63 AMG, land rover
If that's the case, you definitely have a problem...mine will hurt your ears.
Old May 9, 2005 | 03:02 PM
D BLOCK's Avatar
04 sl 55 06 gallardo se 07 s 600 05 hummer sut 04 murcielago
speakers
i have the same problem my sl 55 is much louder than my cls 55 its a very weird thing
Old May 10, 2005 | 12:14 PM
TexAmg's Avatar
2005 C6 (black convt.),2006 CLS 55 (black)
Wow if you can hear the chime then you must have some sort of problem. When my sound is turned up I cant hear anything but the tunes
