Loss %'s on Dyno
Old Feb 26, 2006 | 12:37 AM
vrracr's Avatar
CLS55
Loss %'s on Dyno
all:
i dynoed my 55 today during a euro "dyno day" at Bavarian Hyper Sports in Houston. my wheel HP runs were 406, 417 and 410. the Dyno is off by 3% (needs some calibrating because something happened to it when they moved to their new location). he said my real numbers are in the 431 WHP range.
anyways, what i wanted to know is if it is really possible that less than 10% from the crank to the wheels or is MB really underating these cars? they were saying that on an automatic car, loss should be 20-23%, but mine is either much less or the crank HP is actually over 500.
safeer
Old Feb 26, 2006 | 02:38 AM
idrive's Avatar
2017 SL63
I'm not the expert, but I believe around 18% is closer to the # used for HP loss from crank to wheels.
Old Feb 26, 2006 | 11:22 AM
Evolution Marine's Avatar
2006 CLS55-030, 2002 BMW 540 Wagon, 1995 VW Jetta GLX
Smile Lower Still!
IMO I think it is lower than 15% for Drive Train Loss at the rear wheels. 20-23% is more like what would be experienced with a four wheel drive vehicle, although the higher percentages do make the Tuner look good and the Motor look strong. Using 15% loss would put your E55 HP @ 466HP to 479 Hp at the Crankshaft, which is where it should be. - Bob
Old Feb 26, 2006 | 02:54 PM
Grumpy666's Avatar
This is a good approximation for cars with automatic transmissions, which incur additional losses due to converter slippage and driving the front pump. Typically, the range is 18% - 20%, depending on the car. For manual transmissions, figure on 15% - 17%.
Old Feb 26, 2006 | 10:43 PM
Vadim-SoCal
Guest
Posts: n/a
Do you know what brand it was?
Vadim-SoCal
Guest
Posts: n/a
Do you know what brand of dyno it was?
Old Feb 26, 2006 | 11:07 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
From what I have seen the drive line loss is about 21%. The Mercedes is a very strong and smooth tranny but isn't very effecient compared to some others. I wish the tranny loss was around 15%.
My car is rated at 349hp stock and I dyno'd 290whp with exhaust, K&N's and Evo Pullies. The car is now 360whp with the supercharger.
Old Feb 27, 2006 | 12:04 AM
Question Vadim-SoCal - What Say You?
Vadim-SoCal - So what is the Drive-Train loss on the E55 and the CLS55? Give us a range from the best (least) to the worst (most) for Dynos you are familiar with.
It would be very surprising to me, for drive train loss to be 20%, for a two wheel drive configuration. That would mean that it takes upwards of 93 HP to run the Drive-Train on a stock CLS55 or E55. Also, it is difficult for me to understand why a Drive -Train takes more HP to run it as the HP of the Motor is increased. I would think that the Drive -Train takes "X" HP to run it and as the HP of the Motor is increased this "X" amount of Drive-Train loss becomes a smaller percentage of lost HP at the rear wheels.
What do you think Vadim-SoCal? - Bob
Old Feb 27, 2006 | 02:58 AM
Grumpy666's Avatar
Drivetrain loss is not a constant. It varies with temperature, torque, and RPM. As these variables increase, so does friction. As friction increases, energy dissipation increases. A typical hypoid differential will dissipate 8-10% of the energy applied to it. An automatic transmission will dissipate a similar amount. The remaining losses (1-3%) are attributed to U-joints, wheel bearings, and wheels/tires.
Old Mar 4, 2006 | 11:42 PM
vrracr's Avatar
CLS55
sorry for the late response.
the dyno is a Dynojet 248c.
safeer
