CLS 63 and 030 package
Old Mar 3, 2006 | 03:17 PM
RCTMan's Avatar
Does anyone have info on the release date of the CLS 63? Does anyone know if some, or all of the contents of the 030 package will be standard on the 63? The MB AMG site lists the composite brakes, which currently only comes with the 030 package, as standard equipment
Old Mar 4, 2006 | 12:45 PM
Tony007's Avatar
2010 ZR1 2011 JGC Overland 2013 ML63 on order
I've heard from two central FL dealers that the CLS63 will show up here in June. No info. on the CLS63 030 option package yet..
Old Mar 4, 2006 | 01:11 PM
api3's Avatar
whats the difference between the cls63 composite brakes and the standard cls55 brakes... thx
Old Mar 4, 2006 | 02:05 PM
MB Fanatic's Avatar
4 wheels
The brakes are made of a dual rotor (floating hub) design, also the pads are a bit stronger meaning they can be subject to a bit more heat and tear. Making them a bit more high performance.
My CLS55 with 030 has this. The braking is better than the E55 for sure.
Old Mar 4, 2006 | 02:16 PM
api3's Avatar
thx for the info..
does the brakes look the same?
Old Mar 4, 2006 | 02:18 PM
api3's Avatar
woops, sry. quote the wrong thing.... this is the right one..
does the brakes look the same!!!
Old Mar 4, 2006 | 03:07 PM
MB Fanatic's Avatar
4 wheels
Nope the brake does not look the same at all. The rotors are the ones that are used on the SL65 and CL65. The calipers are the same as the stock CLS55 and E55 but with much much better pads.
Old Mar 4, 2006 | 04:24 PM
RCTMan's Avatar
Not only better performance, but lighter also. This, in combination with the lighter engine should really sharpen the handling.
Old Mar 4, 2006 | 04:31 PM
Kev04C320's Avatar
'09 911 C4S
But the stock calipers still weigh a ton. Time to go aftermarket if you really want to save weight + improve performance.
