Some Questions...
Old Jun 20, 2006 | 12:11 AM
spinsonic's Avatar
magLipVE
Some Questions...
1. How do I enable the "AMG" logo on the nav?
2. Whenever inputing the destination on nav, I would have to select a city. How do I set it to default to a particular city?
3. When enabling sport I/II, does the car sits lower at all speed, even in park?
4. Going from 0-60 and want to get there in a hurry. What method is best; Enabling or disabling ESP? auto gear shift or manual?
5. After winning a drag race, how do I turn on the "LOSER" sign on my rear windshield? (Right now, its the hand out of the sunroof "L") heheheh
Old Jun 20, 2006 | 02:26 AM
Kevin M.'s Avatar
CLS 55
AMG STARTUP SCREEN (3-5-7 trick)
AMG startup screen setup instructions
(see below for picture)
A. Turn on the COMAND and select CD
B. Press and hold the "5" first then press and hold "3" and "7" -- all at the same time for about three seconds
C. This opens a menu with keyboard choices. Scroll down to the AMG and select
D. Press "Back" to the main menu
E. Turn off the COMAND
F. Turn off your car for at least five minutes, so that the change takes effect
Yes at all speeds, when you park and turn off it will sit lower.
Also when sport mode is off completely it will still lower at around 75 MPH as if you were in sport mode.
To funny
Old Jun 20, 2006 | 02:46 AM
vraa's Avatar
I believe Bux (ro0ozy or something was his old sn) made one with his rear sunshade.
It said **** You when you put the shade up with tape
Old Jun 21, 2006 | 03:17 PM
spinsonic's Avatar
magLipVE
thanks for the info!
