Marker Light removal???
'08 Dodge Dually 3500 CTD, '07 Suburban, 2007 MB S550, 2008 Z06, 2008 997TT
I just got my black ones from evosport but before I screw anything up what is the process for removing the orange lights and replacing?? What do you do with the bulb?? Kevin!!!!!..............
to get out the orange ones, you can just pull on it and wiggle it out. the plastic is flexy and this works great.
when i replaced mine with the clear ones, and wanted to remove one of the clear onces that i just put in, i had to do it right since the replacements plastic isn't as flexible. to remove those i had to remove the surround plastic around the front foglight via 3 torx screws. once those are removed, you can fit your arm up behind the light to pop it out from behind...
