upshift indicator
Old Jan 3, 2007 | 01:40 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
upshift indicator
I saw this on the ML63 forum, which was taken from the E63 forum. NOt sure how useful it is but ...
https://mbworld.org/forums/showthrea...=1#post1914886
On another note. Does your "M" mode shift fast enough? What happens when you redline? When I redline, it won't shift for a second or so which basically means I redline even more which sucks. Needless to say I don't use the "M" mode anymore. I'l have dealer check it out to make sure it's working correctly.
Old Jan 3, 2007 | 04:29 PM
TREZ63's Avatar
okay I tried this today and it's actually pretty cool. It works pretty well and it lights up before redline which is perfect. It's definitely the best way to shift in M.
Old Jan 3, 2007 | 10:08 PM
amgbenz55's Avatar
06 CLS55 - Silver/Black
ok what display mode do you put it in on the cls55?
also you mentioned something about dyno mode? what is that?
Old Jan 4, 2007 | 03:41 AM
TREZ63's Avatar
I have it in the oil level screen which also shows the actual gear you're in. I am also told it's only on the 63 engines.
Dyno mode, is when you have it on the temp/speed screen (depending on what you have it set to) the hit the reset button three times. Go thru the menu hitting the up arrow button (not down arrow) then hit + to turn on dyno mode.
Old Jan 4, 2007 | 12:00 PM
amgbenz55's Avatar
oh interesting...i wonder if this feature isnt available on the cls55?
Old Jan 4, 2007 | 12:14 PM
Schiznick's Avatar
SL65, E55T, Pending S65
dyno mode yes and upshift light no for the CLS55
Old Jan 5, 2007 | 04:56 AM
Carbonlord's Avatar
What exactly is the dyno mode?
Old Jan 11, 2007 | 05:09 AM
Carbonlord's Avatar
Old Jan 11, 2007 | 09:45 AM
Schiznick's Avatar
Dyno mode is found in the diagnostic screens of the dash. My guess is that it exists so that techs can run the car on the dyno without all of the electronic aids getting in the way.
In dyno mode it completely shuts down ABS and ESP allowing you to run your car on a chassis dyno without your car trying to apply the brakes.
If you do a search on this board you will find out how to get your car in dyno mode.
Just remember, this is a diagnostic mode and while some people drive in this mode (including me at the drag strip,) you have NO driver aids at all running on the car.
This can be quite dangerous and is not for the faint of heart.
Cheers!
Schiz
Old Jan 12, 2007 | 11:03 AM
BenzoBoi's Avatar
Super Moderator
W221
Like Schiznick said before...Once you put your car in DYNO mode, it will stay there even though you turn the car off and back on. You have to manually go back in there and reverse the process to get out of DYNO mode...
