air filer
Old May 8, 2007 | 02:58 AM
spinsonic's Avatar
magLipVE
air filer
does anyone know if there is an air filter for the central air? if so, where can is it located? need to replace mine.
Old May 8, 2007 | 05:29 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
my AC has a bad oder coming form it when i first turn it on, then its completely fine... will changing filters fix this?
if so where r they located? is it easy?
Old May 8, 2007 | 10:06 AM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
I believe when facing the open hood, it's at 10 o'clock.
Old May 8, 2007 | 01:26 PM
spinsonic's Avatar
magLipVE
EXACTLY!
Old May 8, 2007 | 03:24 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
I would say if its more than a year old, B&G Systems has a AC duct flush to fix this problem. Check for an B&G Systems certified shop to do this service.
Also, no matter how gross it may sound, I have heard that some ducts had dead rats in it. Hopefully you are not in New York.
A hint from my own experience:
1. Check for clogging of the evaporator drain line-it should drip condensate water freely.
2. 3-4 minutes before your turn your car off, first turn off just the ac switch while leaving the fan switch on so that any condensate can drain off. This is a good preventative measure every car owner.
Old May 8, 2007 | 07:35 PM
chutia's Avatar
06 CLS55 AMG-all options sans Distronic; Carrera4S; 07 M5;Lexus GS300
the last 2 tips from m berman are right on...for all cars. NOTHING prevents odors, keeps the AC vents themselves fresher and freer of mold, etc. than the simple procedures recommended by m berman.
Old May 8, 2007 | 11:39 PM
spinsonic's Avatar
magLipVE
thanks, i'll give that a shot. the odor usually go away after about a minute of running the ac. hopefully the drain off will fix the problem
