sound system
Old May 29, 2007 | 08:48 PM
spinsonic's Avatar
magLipVE
sound system
anyone here upgraded their sound system? Basically, am looking to add a little more low end bass, along with some highs. thinking about some sort of bass tube, like a bazooka in the trunk. how would they connect them to the stock head unit?
thanks in advance
Old May 29, 2007 | 09:03 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
+1
Old May 29, 2007 | 09:38 PM
Bipasha493's Avatar
CLS 55 AMG
+2, but i prefer JL audio for the low end
Old May 29, 2007 | 10:30 PM
Htowncls's Avatar
CL63
kicker solobaric if you are going to get something customized.
Old May 30, 2007 | 02:30 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
does MB not offer an upgrade to amg cars from standard? and is their not a further upgrade Available?
I am thinking the same as sound is not one of the strongest points
my dads 1998 s320 sound system blows my cls away so bad its not funny
think they are boss
Old May 30, 2007 | 04:12 AM
amalamud's Avatar
CLS55 06 (K4, LSD), Range Rover Sport 06, Bentley Flying Spur 07
I spent 25K on the sound in my car. JL subs, Alpine amps, MB Quart signature speakers, sound & vibra-isolation. Went to a car audio competion last week, got first place in 4 categories including best sound and best in show. Not that I like to brag... Will have pics later.
Old May 30, 2007 | 05:07 AM
Nice's Avatar
I spent about $12k on my system. The stock radio is a complete joke. One item i reccomend is some newer type of high/low converter that rockford makes to hook up your sub. It has a bluetooth connection to a pda and allows you to tweak in the sounds to your liking. I went with JL amps/sub with Morel highs. I couldnt be happier.
Old May 30, 2007 | 08:05 AM
Bipasha493's Avatar
CLS 55 AMG
the factory system in my cls sounds like it has a "limiter" on the volume and is capable of being much louder. You guys with the aftermarket systems, did u use the stock head unit? Is there a way to bypass that limiter thingy?
Old May 30, 2007 | 01:08 PM
spinsonic's Avatar
magLipVE
ouch 20K??? no, i am not trying to rock the car next to me apart. Just need a bit more highs and lows. stock sound system is a joke!
my fiances 30k acura sounds 100x better. i offered to swap cars with her a few times, and she said "no thanks, your system sucks"
Old May 30, 2007 | 01:40 PM
Bipasha493's Avatar
CLS 55 AMG
the stock boston sound system in our chyrsler 300 is 100 times better then that of the harmon kardon
Old May 30, 2007 | 02:28 PM
slang500's Avatar
07 CLS 63, 87 L6,raised TITAN,62 custom beetle,72 monte carlo,2 civics
I wanna do a system in my cls here pretty soon , i know im either gonna go with everything jl or maybe a little higher end like macintosh . A jl high/low converter is the best way to get your sound right other than that you gotta switch your head unit out which is something no one wants to do..? Im gonna start in a couple of weeks so wait for the pics..
Old May 30, 2007 | 02:42 PM
traumadoc's Avatar
2022 AMG SL 63. 2021 APR stage 1 Audi SQ7.
Infinity
I bought a sub and a 760 watt amp. Helps the lows. Highs are still rather weak.
Old May 30, 2007 | 03:21 PM
spinsonic's Avatar
magLipVE
yea, i heard about the jl convertor. do you happen to know what model? also, does it allow you adjust the outputs on the stock system? i'm thinking about just adding a simple powered bazooka tube. if the convertor allows me to adjust the highs and mids, that would be awesome.
Old May 30, 2007 | 05:09 PM
Stiggs's Avatar
2003 CLK55
If you switch out the stock head unit will you lose the steering wheel controls?
Old May 31, 2007 | 01:30 PM
Nice's Avatar
Adding bass will not solve the problem. I know this first hand. First I installed my sub & amp and added a second amp to the stock speakers to get more volume. The high/low converter I used has an eq via bluetooth so they used a pda to take out all the lows from the mids/highs to offset the added power. They still souded like sh*t. My advice would be to replace the mids/highs first and ad an amp. I have a gain knob for my sub and when turned off, the Morel mids/highs sound excellent. I have no real need for a sub accept for the fact that I like the Boom.
Old Jun 1, 2007 | 02:53 AM
mig888's Avatar
EVE
its not rocket science you need a converter such as the jl clean sweep and or the rockford fosgate 360 which can be controlled by bluetooth phone. The stock amp is located behind the carpet on the left side once you remove the carpet panel look behind the area where the hinge is for the trunk and behind it you will see the factory amp . its bolted in by 10mm nuts i believe 3 of them.
Old Jun 1, 2007 | 08:50 AM
Dogshine's Avatar
CLS55
bp- i believe you are correct. there is one cheater bypass which is to use an ipod and run it thru the audio jack in the glovebox with the ipod volume turned up around 3/4 of full. you will get louder sound and a little more bass. (it doesn't turn it into a different system, but does boost it a bit)
Old Jun 1, 2007 | 10:29 AM
Sreilly's Avatar
ON PROBATION
I have done numerous Sub add ons and system upgrades in MBs and we tend to go with Jl clean sweep and JL or Alpine PDX amps as well as Alpine and JL speakers (really depends on your budget) the only draw back is that you will need to use the cleansweep to control the volume of the system. This is A minor change to get great sound
www.sraudioworks.com
Old Jun 1, 2007 | 09:54 PM
spinsonic's Avatar
magLipVE
so i went to the local stereo shop today and this is wat they recommend. they say total weight is probably going to be around 100lbs. their going to leave the stock mids and highs. i actually prefer the bazooka tube for bass, but the guy says bazooka is going to sound terrible, he recommend building narrow box with a single jl 12". what do you guys think?
1 cleansweep
1 ssi module
1 jl 300/4 amp
1 jl 500/1 amp
1 12" jl wg sub
Old Jun 1, 2007 | 11:53 PM
Stiggs's Avatar
2003 CLK55
1 cleansweep
1 ssi module
1 jl 300/4 amp
1 jl 500/1 amp
1 12" jl wg sub
What is the cleansweep and the ssi module?
Old Jun 2, 2007 | 01:49 AM
spinsonic's Avatar
magLipVE
from what they tell me, the ssi module basically flattens the signal before going into the JL cleansweep device. cleansweep basically allow you to connect other devices, such as amplifiers and stuff to the stock head unit.
more info here http://mobile.jlaudio.com/products_c...hp?prod_id=369
Old Jun 2, 2007 | 02:08 AM
Nice's Avatar
1 cleansweep
1 ssi module
1 jl 300/4 amp
1 jl 500/1 amp
1 12" jl wg sub
I suggest changing the mids & highs first but either way I think you will find the stock mods & highs to be lacking and will swap them. My suggestion woulld be to have the sub fire through the center arm rest cut out of the back seat. This will keep truck rattle to a minimum.
Old Jun 2, 2007 | 08:53 PM
spinsonic's Avatar
magLipVE
nice, thanks... yea, i think their going to put a narrow box that covers the whole space behing the back seat, with the sub port hole coming out of the arm rest.
by the way, you mind posting some detail pictures of your set up?
Old Jun 2, 2007 | 09:34 PM
france2112's Avatar
2015 Mercedes-Benz CLS63 AMG S
Reus Audio Systems
Any of you audio guru's hear the Reus system for the CLS? I hear they use their own speakers in place of the stock and place a few more in covert areas. The head unit remains stock but I understand they get amazing sound. I've personally never heard any of their work but I have read about them from other forum members. I believe it is about 3K to do all their modifications. I'm just wondering if any of you audiophiles know their work.
Old Jun 3, 2007 | 01:20 AM
spinsonic's Avatar
magLipVE
just checked out their site, looks like they do really nice work. only thing is that i doubt it will sound better then the JL set up.
