seats, memory, and key fobs
Old May 30, 2007 | 11:53 PM
scottmlew's Avatar
Looking! (previous: CLS55)
My understanding is that when you open/start the car using keyless go, the seats/mirrors/wheel should return to the memory position last used by that key fob. This is not the behavior I'm observing (it does nothing at all). Can someone confirm that what I'm expecting should be happening, and perhaps propose how to resolve the problem?
Thx to all of you for humoring all my questions -- it is truly appreciated.
Old May 31, 2007 | 12:33 AM
Kevin M.'s Avatar
CLS 55
Hmm, thats not the case with mine, I have to use the memory buttons after wifey takes it out. Did you read this in the manual?
Old May 31, 2007 | 02:25 AM
scottmlew's Avatar
Nope, I didn't read it in the manual, but:
1. my salesman said is works this way
2. a few posts (on this forum) for older model Benzs talk about this behavior
3. a lot of pretty common cars do this (not with keyless go, but working off the key fob)
4. it's common sense that it should work this way
Old May 31, 2007 | 02:06 PM
Kevin M.'s Avatar
CLS 55
1. my salesman said is works this way That's the funniest thing I've heard all week, they are usually lacking in the knowledge department
Thats correct the older cars use to do that, I guess they elminated it, people probably share keys to much, and don't want the seats to move maybe?
3. a lot of pretty common cars do this (not with keyless go, but working off the key fob) My Cayenne remembers stereo and AC/Heat settings, not seats though
Old May 31, 2007 | 07:36 PM
chutia's Avatar
06 CLS55 AMG-all options sans Distronic; Carrera4S; 07 M5;Lexus GS300
Perhaps I can shed a little light on this matter, having gone through this exercise, albeit for a different reasons, w/ my dealership recently:
1. the seat, rearview mirrors, steering column settings are supposed be able to be set either key-dependent or key-independent (I'm not sure if this is a user-programmable option).
2.Ergo, when you program/reprogram your memory 1 settings, then the keyless-go/electronic key is supposedly downloaded these settings. Now, each time you enter the car, these settings are supposed to be set in accordance w/ the memory 1==>keyless-go settings IF your setting is set to key-dependent=yes.
3. Now, logical question: is this efficacious? Don't know b/c I had my key-dependent setting set to "no," the keyless-go settings do NOT reset or control the above settings (this was b/c we were trying to solve a particular problem w/ the AMG seats (I have a blog here a while ago on this subject)).
Not sure this helps, but that's all I know re this matter.
Old May 31, 2007 | 08:06 PM
hsandhu21's Avatar
2015 s550 sport, 2017 e300 sport
Cool It's In the menus
From my experience and what I've read in the manual. You have to go through the menu's with the arrows on the wheel and one of them should say Key dependant or not I believe it is under the settings menu I'll check it out a bit when i'm home and let you know. Not sure if that really helps
Old May 31, 2007 | 11:42 PM
scottmlew's Avatar
Yes, I know I should never trust my salesman... With that said, he now said that MB discontinued that feature for or after (I forget which exactly he said) the 05 model year, so the older cars WILL behave this way but the newer cars will NOT.
I don't seem to have a "key dependent" option on my 06 unless I'm missing it. Does anyone else have this?
Old Jun 2, 2007 | 04:25 PM
chutia's Avatar
allegedly, mine does; 06.
Old Jul 17, 2007 | 01:40 AM
MissMyBenz's Avatar
'03 ML500, '07 E350 Sport (wife's)
My 07 seems to be lacking the menu option of key dependent. Without that, do the keys function identically?
