Renntech settings
Old Jun 14, 2007 | 02:41 AM
spinsonic's Avatar
magLipVE
Renntech settings
anyone here have the renntech lowering module installed? what setting are you using for front and rears? i have mine set at 1 for the fronts and 7 for the rears. the car is slammed... so i'm a bit concern if this is going to damage anything.
i'm also confuse on why the rears are so low, with the setting at 7. any number below that is not driveable...
thanks
Old Jun 14, 2007 | 11:59 AM
troy@kronen's Avatar
thanks
All non-AMG Mercedes models should use a setting of 3 or higher.
AMG cars are lower than their Mercedes counterparts. With this
in mind it is recommended that AMG cars use a ride height setting
of 5 or higher.
Lower settings can be used for show purposes but are not recommended
for everyday driving.
Old Jun 14, 2007 | 12:17 PM
newton22's Avatar
BMW E39
0-0-0 is the way to go.
Old Jun 14, 2007 | 12:22 PM
Doesnt sound right have shop double check install.
Old Jun 14, 2007 | 04:30 PM
spinsonic's Avatar
magLipVE
thanks guys.... i had the car lowered via the washer prior, so it wasnt taken out when the module went in.
Old Jun 19, 2007 | 06:47 PM
joemoney415's Avatar
2007 cls 63 030
I have it on 1 up front and 2 in rear and dont have any problems. Just press the vehicle raise button when entering or exiting a driveway. Car will still scrape on some things due to the long wheel base. Usually it is those little flaps in front of the rear tires or way underneath in the back of the front air dam.
Old Jun 19, 2007 | 06:56 PM
spinsonic's Avatar
magLipVE
you dont experience abnormal tire wear with that setting?
Old Jun 21, 2007 | 02:48 PM
Alex@Creative's Avatar
ABT B7 AS4 & 07 S550
something with your wiriing is backwards. definatly have a shop uninstall and reinstall the module to make sure everything is perfect
Old Jun 21, 2007 | 03:44 PM
James@Creative's Avatar
Setting at 1 in the front and 2 in the rear
Old Jun 21, 2007 | 03:50 PM
spinsonic's Avatar
magLipVE
james/alex, thanks... my car was lowered via the washers prior and it wasnt removed, when the module went in. I have it set 3 for the fronts and 4 for the rears now.
