55 steering and suspension creaks: common problem??
Old Jul 17, 2007 | 01:04 PM
chutia's Avatar
06 CLS55 AMG-all options sans Distronic; Carrera4S; 07 M5;Lexus GS300
For the last few months I've noticed a regular groan and creeking from the suspension (all around) and especially when the steering is turned off dead center in either direction. Persistent and easily heard. I suspected that since the car is immaculately taken care of and never "abused" this must be a common characteristic of the steering/Airmatic/suspension.
Took it in to the dealership, who had their top suspension tech look at it, and after the usual "we don't see it" routine, completely acknowledged that it was there and actual and factual. Luckily there was a 9K mileage 55 also for sale at the dealership, so we had it pulled up and....lo and behold, same "problem/characteristics" as mine, except less vocal.
Whether this is a "standard" issue characteristic or not, it still sounds pretty bad. Anyone have any experience or knowledge re this...appreciate group's input. thanks!
Old Jul 17, 2007 | 03:34 PM
joeybenz106's Avatar
2007 cls 550
I havent had this problem yet but then again i only have 870 miles on my car. i hope this isnt a "standard problem/characteristics"
Old Jul 17, 2007 | 04:19 PM
clos's Avatar
06 CLS55
I'm @ 22,340 and yes it creaks, I had this same problem with my E took it to the shop so many times I gave up. I think it needs to be lubed properly something that is always overlooked.
WD40?
Old Jul 17, 2007 | 04:43 PM
chutia's Avatar
thanks all. Don't know if it's a safety concern, esp when driving 7 or 8/10ths even, but once again, and the dealership I take my car to has surprisingly good customer service, this is the first they've heard of it. As much as anything else, the latter response is what surprises me, esp when others obviously have the same problem, like clos encountered.
clso-what did you find needed to be lubricated and w/ what?? WD40 sounds good, as does that pop-up ad here for Jig-a-Loo (LOL!!!! is that like Astroglide for MB suspensions?! LOL)
Old Jul 17, 2007 | 05:58 PM
clos's Avatar
06 CLS55
i'm guessing
Don't really know but my guess is if everything comes out normal on diagnostic then it only leaves the KISS effect. Keep It Simple Stupid, the squeaky wheel gets the oil. Don't really know where to spray but it was the first thing I thought of to get rid of the noise.
So in retrospect what I did to get rid of the noise on the E was buy a new CLS55 wife wasn't to happy but I got rid of the noise. I guess its back to the drawing board on how to solve my current problem
Clos
Old Feb 7, 2014 | 08:05 AM
Julian77's Avatar
CLS 55 AMG IWC (W219), SL500 (R129), D250 (W124), A140 (W169), ML270 (W163)
suspension creaks
Hi everyone,
I had front suspension creaks on my CLS55 that first started coming after using the level change (and slowely going off after a while). These creaks (very irritating I shall admit) over the time started to be more and more constant even without changing the level and not only when passing over a traffic bumper, but also on relatively small roughnesses on the road.
Visited the authorized service twice but the car was relaesed only with a check saying it's all OK.
Recently I went to a guy who previously worked at an authorized service of MB (now working on private) and after checking all the joints and others - the problem appeared to be the reactive rod - changed it and all the noise has gone.
Hope this helps as sometimes going to the service you shall be prepared to ask for what is to be done.
Cheers,
Old Feb 7, 2014 | 05:31 PM
omar26's Avatar
E55
1
Old Feb 8, 2014 | 12:15 AM
Kevin M.'s Avatar
CLS 55
Any more details, part number location of part?
Old Feb 8, 2014 | 08:46 AM
omar26's Avatar
E55
It is the entire sway bar. The bushings on them go bad, but dealer sells it as a complete unit. No more creaking noise after that. I took it to the dealer to get it diagnosed and they tried telling me to change the lower control arms, sway bar links, and one other piece, but none of it worked. Took it to my friend who is a mechanic and swapped out the sway bar no more noise after that.
Old Feb 8, 2014 | 12:47 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
I had a similar creaking problem. It was gone after my indie and I changed the ball joints and tie rod ends both of which were toast at 50k. If there is a creak there is a reason. For me I don't want a 100k plus car sounding like a bucket of bolts going down the road. More importantly is the safety factor. Have them check your front suspension. Oh and my front tires were wearing perfectly at the time so even wearing tires is not necessarily an indicator of the condition of the front suspension.
