What are you tire presure running?
10K miles on P Zero Rosso, warm tires.
I'm currently on 20" CEC wheels with 255/30 front & 295/25 rear.
CEC has recommended to be at 4 psi above the stock 19". so I'm at 42 / 45.
Car rolls better. I have gotten real good gas mileage when travelling at normal speeds. I think anything between 40-50 is likely beneficial. I was told by my tire guy the maximum pressure will allow the car to roll better and that the fronts should always have more pressure in a rear wheel drive vehicle. On the track I keep the fronts at 51 and lower the rear to 28
Rating on the tirewall is the most misleading. This is the maximum pressure rating each tire will sustain, but then each PZero is different based on the car it's on, whether it's a 2000+ lbs Porsche or 4000+ lbs AMG...
The car tire pressure rating on the gas door/inside the door, etc... is the same general setting each car manufacturer recommends for the car, not optimized for performance or fuel economy...
Rolling resistance, inertia, coefficient of friction, etc... all play a role. In the simpliest analogy, higher pressurized tires will roll like a marble on a skillet; whereas lower pressure will allow the tires to set and roll like a wad of gum, but it will enable for a relatively stickier interface and may lead to higher handling threadshold. Better rolling with higher tire pressure has proven to improve gas mileage appreciatively, hence I'm playing around with it.
