Evosport Performance Rotors in Stock!!!!
Designed as a direct brake disc replacement for the OE 55 AMG brake discs on all four corners (No modifications are necessary. The disc will bolt directly to the car and work with OE AMG brake calipers). Not only will the upgraded multi-piece "floating" discs help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them. Available drilled/slotted or just slotted. Front 14.2"/360mm, Rear 13.0"/330mm. For use with OE AMG brake calipers only - E/CLS 55 AMG Kompressor.
We also have the upgraded Pagid performance brake pads and stainless steel braided brake lines available as well. Call or email us for more info.
For more info: http://www.evosport.com/product/prod...VO.BRK.M5K.R03
Drilled rotors shown below (drilled/slotted only available now):
Dale
