air box + tubes, will it fit?
Does any one know if our cars differ in the engine compartment much then the E?
i was thinking of air box + tubes... but not sure if they would fit the CLS .
Can any one chip in ?
is the mod worth it?
does it give gains?
will it fit
does it give gains?
will it fit
You name it i've had it or got it...
i don't know the way the airbox sits so i can't answer that ?...but i can say that make sure you do the ecu and the pulley 1st...huge difference!!! then do other mods...
a car that gets very poor gas mileage.
is the engine bay of the CLS the same as the E?
Other question was do they actually give you any gain?
Pully is an ify mod for me as i live in extremely hot country, and do not want to worry about heat all the time when i drive ... maybe if i get cooling mods, but that just makes my mod list bigger and bigger.
My aim is to mod the car with out really hearting it or the warranty, just trying to figure out if they are worth it.
- 80mm TB
- Air box + tubes
- maybe play with the exhaust
- ps2 tiers for some better traction, once the current ones are worn down
could possibly get headers to, but trying to find out as much as i can before i make up my mind
2005 SL55 AMG
there are two airboxes, one on each side. and there are two air tubes, one on each side. the airboxes are the exact same. i'm pretty sure the tubes are as well. im not 100% sure about the tubes though.
