295 30ZR 19s on stock 9.5" rear wheels okay??
It is time for new tires on the CLS55 and I have found the choices very limited in the rear OEM 285 30 zr 19 size. For instance, if you want michelin ps2s, continental conti sportcontact3s or the up and coming Vredestein ultrac sessantas, you have to go with the 295 30 zr 19 size for the rears.
If one looks at the tire manufacturer's specs at tirerack or elsewhere, the overall diameter, section height, wheel-tire rpm doesnt change significantly from the 285 to 295 change but the section width of the tire will go up about a 1/2 inch.
The following are my questions for those far more knowledgeable and experienced on this board than a newbie like myself (and i did not find any relavent threads on searching):
1. Is this half inch a problem for rubbing clearance?? I would rather not roll my fenders and I would doubt that I would have to given some of the beautiful wheel tire cobos that I have seen members have on this board.
2. From a handling perspective, does this slight increase in the front rear stagger from 255/285 to 255/295 cause any significant/appreciable change such as increased understeer that one would notice negatively?
3. According to the tirerack spec charts, they reccommend a 10 to 11 inch wheel diameter for the 295 30 zr 19 size. can I get away with the stock 9.5 inch diameter wheel for this size? Will the slightly narrower wheel just cause the tire sidewall to bulge a little more and act like a rim protector? will it cause the tire to appear or act like a 25 aspect ratio rather than the 30 it is?
4. Are there any other factors that I should be considering? all advice is greatly appreciated!
As long as your tire pressure is kept to manufacture guidelines you should get a better ride out of these tires then stock. I am not a fan of to much of a low profile, I like to know I have some meat on my tires.
My 2 cents.
My 2 cents.
