LOWERING KIT for CLS63
Old Dec 12, 2007 | 06:47 AM
yaroslav's Avatar
GL550 , CL6.3 AMG
I want to order Lowering kit and need some answers:
1) How it drives in "LOW" mode?
2) Will it rub in LOW mode if i have 20 wheels?
3)Which brand is better?
Thanks for advices!
Old Dec 12, 2007 | 11:30 AM
Big Carrot's Avatar
CLS 55
Thanks for advices!
1) A little stiffer.
2) Depends on how much you lower it.
3) Depends on how you do it. There are several ways to achieve the same effect.
Old Dec 12, 2007 | 11:32 AM
yaroslav's Avatar
GL550 , CL6.3 AMG
What do you mean several ways?
Thanks for the answer man!
Old Dec 12, 2007 | 01:10 PM
rbtronnie5's Avatar
You name it i've had it or got it...
renntech elm is fully adjustable and electronic. the only other way to achieve what you want are the adjustable arms. but they are a ***** to adjust.
Old Dec 12, 2007 | 02:49 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
A curious question:
Does the alignment change with each height setting? And if so, does it get out of wheel alignment spec (factor range for caster, camber, etc.)?
Old Dec 12, 2007 | 03:26 PM
rbtronnie5's Avatar
Originally Posted by m_berman
A curious question:
yes it does change the camber with each setting....from very slightly to extreme....the more you lower it obviously the worse it will be. when you go over 1 1/2 inches you run into having to get a camber kit etc...to get it factory specs.
Old Dec 13, 2007 | 10:59 AM
Big Carrot's Avatar
CLS 55
You can do a control module, lowering arms that trick the sensors, or by placing washers on the front and bending the rear arms. You achieve the same results with all three, but the cost of each varies dramatically.
