How to disconnect traction control completely?
A guy at the dealer showed m but I forgot, it can disconect th traction contral completely and it also diconnects the ABS.
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
CLS 55 AMG
GO in Dyno Mode
in order to go into duno mode, u will need to follow these couple of steps:
1. shut the engine and leave the gear in N
2. Make sure your speedo dial shows the outside air temp.
3. use the key and turn it to position 1
4. when u ture the key to position 1, press the speedo reset button 3 times and hold it there till u see the speedo dial reads DYNO MODE.
5. use the button on the steering to switch the Dyno Mode on.
When it is switch on, you will not have any electronic assistants. Pull off the Dyno Mode when finish using it. It is very dangerous to drive without any elelctronic assistants
dyno mode
Thanks a lot!! Thats is correct !
2001, continental, control, disconnect, disconnecting, drive, dyno, electronic, engne, h2, hummer, mercedes, mkbcls55, mode, traction, turn
