Car is shifting too early
Old Jun 26, 2008 | 02:04 PM
lexaltezza's Avatar
08 CLS63
Over the past couple of days I noticed that if I hammer it at about 40mph, the transmission will downshift in a lower gear then at exactly 6k rpm's it will shift into the next gear. However, after that it will start to shift again at close to 7k rpm's. I even reset the adapative ecu a few days ago to no avail. Does anyone else's 63 do the same thing?
Old Jun 26, 2008 | 11:00 PM
juicee63's Avatar
2011 twin turboed prius
When hitting kick down the car should always go to at least 6500 , 2nd to 3rd should be 7-7200 WOT. 1st gear, is usually the culprit but sounds like your TC is causing an early shift. Try doing some tests with TC off, and or in DYNO mode. Car should go to 7200 in every gear except 1st
Old Jun 27, 2008 | 10:55 PM
Centurion's Avatar
a car that gets very poor gas mileage.
I'm assuming you're in "S" mode.
Wouldn't it be better if you downshifted yourself with either the paddle or shift knob then floored the throttle? TCU should upshift for you at redline for each successive gear.
Old Jun 28, 2008 | 01:46 AM
juicee63's Avatar
+1
