Where are the interior air filters?
The charcoal filter is located just under the plastic cover above your feet in the foot well, on passenger side.. Do a few searches and you will find instructions. Pretty easy job and well worth the clean air..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
